wheel question
  • erehemantresni
    • 136
    wheel question
    16x7.5 Borbet et20
    1989 325is
    what size tire could i run on a mildly lowered car?
    would spacers be needed w/this rim?
    thanks
  • DSchultz325e
    • Aug 2004
    • 1158
    if these are from tirerack they will come with the hubcentric spacers. at least thats what they told me when i asked about the type Es.
    I retired my E30 for now...
    E46 323i
    David Schultz
      • 34844
      if the rim is already ET20, then no you don't need spacers. Borbet wheels on the tirerack are all ET35 though.
      • Rob
        • 8166
        215/45 should fit that rim perfectly
        BEERTECH
        • erehemantresni
          • 136
          awsome thanks rob...you think id have trouble running 225's in the rear?
          • Rob
            • 8166
            with early arches, shouldnt be a problem, but staggered setup is nowhere near ideal for handling unless you're making a ton of power
            BEERTECH
            • erehemantresni
              • 136
              :twisted:
              le boosta
              • Digitalwave
                is a poseur
                • 6299
                That's undersized, you either want 225/45-16 or 205/50-16.
                RISING EDGE
                • Rob
                  • 8166
                  undersized by 1.5%, which is negligible. plus azenis come in that size.
                  Tire selection for 16" blows
                  BEERTECH
                  • rwh11385
                    lance_entities
                    • 18403
                    Ted runs that size, and likes it.
                    And just to say it, Rob said the tire would fit the rim perfectly, and said nothing about tire diameter. :P So there Teej.
                    btw, I ran 205/50-16 on ET20 16x7.5 Borbets, and they only rubbed very occasionally.
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      215 Azenis + 7.5" rim + ET20 + late model would very likely rub, but fender rolling will fix that good. Besides that, it's like the only tire available in that size anyways.
                      I'd say get 205/50/16 for now (shitload of good tires in that) and see if you have the extra room afterwards. The 7.5" wide rims will provide an effectively bigger contact patch anyways, should be plenty.
                        • 34844
                        if these are street wheels (probably as borbets are heavier than shit), there's a much better selection of tires in 205/50 and they shouldn't look at all stretched on a 7.5" rim. azenis aren't something I'd want to run on the street, at least not around here (rain, rain, and more rain!)
                        I had 205s on my old 16x7.5 wheels, they fit fine. but I'm thinking of going with kosies in 16x7.5 with 215/45 azenis; on the track who cares if they're undersized ;)
                        • rwh11385
                          lance_entities
                          • 18403
                          Not all borbets are THAT heavy, punk.
                          You'd care if they are undersized.....they'd be more fun. ;)
