Wheel Size
  • E30Driv3R
    • May 2004
    • 1169
    Wheel Size
    I was just wondering what size SSR Competition wheels are the best for over all performance on autocross on a 318iS?
    Dan Zickel
    1995 M3, 1991 318iS, 1987 325iS
  • Brew
    • 3060
    Probably a 15x7 with 205/55 for the lowest possible unsprung weight.
    '91 318is
    • Mystikal
      Wheel Fitment Expert
      • 9602
      15x7 for sure, but 205/50 if you want to run street tires (Azenis Sports) or 225/50 if you want R-compounds.
      • E30Driv3R
        • May 2004
        • 1169
        I was just wondering, y is 15in better, i thought that the bigger the wheel, the better i guess handling like a 16 or 17 ini dunno tho thanks for the help.
        Dan
        Dan Zickel
        • chrisd
          • 288
          the 15s have lower mass and thus allow faster acceleration & (slightly) better braking... every .001 second counts!
          • trent
            Wrong.
            Best tire choice for R-Comps is 225/45/15. Gain gearing too. Of course this is track dependent.
            • E30Driv3R
              • May 2004
              • 1169
              i know about the 15x7 but would a 16x7.5 be to large, for just normal use and maybe every once in a while autocross?
              also would a 205/55R16 tire fit on that i dont really know if that is enought info for you guys i dont really know that much about tires.
              Dan
              Dan Zickel
              • Brew
                • 3060
                Dan
                Definitely not. I personally would go for the 16x7.5 myself. The proper sizes would be either 205/50-16 or 225/45.
                '91 318is
                • E30Driv3R
                  • May 2004
                  • 1169
                  Ok thanks
                  Dan Zickel
                  • BimmerHeadBri
                    • Oct 2004
                    • 48
                    Tire size comparison Link
                    This link will give you the proper sizing for your tires so your speedo is not off by too much when changing tire sizes.
                    Pretty simple to use.
                    Cheers.
                    http://www.miata.net/garage/tirecalc.html
                    BimmerheadBri
                    '86 325 (eta)
                    • Mystikal
                      • 9602
                      Yeah, good link. But as trent pointed out and I noted with the 205/50 size, undersized tires are generally better for auto-x (shorter gearing).
                      • E30Driv3R
                        • May 2004
                        • 1169
                        Sorry im in school right now and dont have time tocheck but does any one know what the stock tire size is ill check after classes.
                        Dan Zickel
                          • 34844
                          • E30Driv3R
                            • May 2004
                            • 1169
                            ok thanks is there any thing else i should look into for buying new wheels?.
                            Dan Zickel
                            • Mystikal
                              • 9602
                              Well, are you just looking for track wheels?
                              I'd also take a hard look at the Team Dynamics Pro Race series, those 2 wheels are the right offset (won't need spacers like the SSRs) and are still really light.
