Minimum Offset for 15x8" wheels?
  • Streetspec_iS
    • 1622
    compomotive mo are pretty heavy from what i have heard/researched.
    sigpicM42 Brigade ... Throwing craze in the 318
    • M-technik-3
      • 18946
      15x8 et 12 in my BBS RS071's No clearance issues with 225-50's
      • Chapel
        • 633
        15x8" Comp MOs are 18lbs but are impossible to bend.
        They are designed to be a 'lightweight' rallye tarmac wheel.
        not a lightweight autocross wheel
        BattleWagon|1996 GT Vertigo
        • M-technik-3
          • 18946
          To heavy for me. My RS's are 14 lbs in 15x8 but bend when hit hard.
          Have you mounted those bumpers yet?
          • Chapel
            • 633
            not yet.
            kinda waiting until later in the winter.
            Plus I'm buying a new car soon... Something big... with a V8 :twisted:
            • Tony S
              • Apr 2004
              • 88
              22mm offset for 15x8 on all four corners, this will allow you to rotate the wheels.
              I have the Kosie K1's on my car. You can call Jim @ tirerack, they keep blanks of these wheels in stock and they can machine them for you. 15x8, 22mm offset, 57.1mm centerbore. They were low on stock but more were coming in.
              • Digitalwave
                is a poseur
                • 6299
                With the blanks they do everything custom, the offset, center bore, bolt pattern?
                RISING EDGE
                • Brew
                  • 3060
                  Everything but offset, I believe.
                  '91 318is
                  • Tony S
                    • Apr 2004
                    • 88
                    Yes they do the offset too.
                    • Brew
                      • 3060
                      I didn't think they machined the mounting face- at least thats what this list led me to believe: http://forums.bimmerforums.com/forum...21&postcount=2
                      I could be wrong.
                      '91 318is
