How much paint for baskets
  • e30evolution
    West Werks
    • 1888
    i am replainting all four of my euro basket weaves 15's, and i am wondering how much paint i will need i will be gettting wurth wheels paint... but they are sold out so i am getting z1 wheels paint.... which is the same paint, same manufacturer and everything... please let me know what your experiences are with these paints.... i was kind of thinking 1 can per wheel
    http://www.westwerksauto.com
  • Digitalwave
    is a poseur
    • 6299
    3 cans will probably do.
    RISING EDGE
    • UNHCLL
      • 8790
      3 cans of silver if you plan on doing inside/and outside of wheel.
      3 cans of clear coat to do same as above.
      If you dont do Clear coat, dont even waste your time.
      Below the radar...
      • e30evolution
        West Werks
        • 1888
        i have dupont chroma clear..... and i have a sata jet 2000 gun... is there any kind of wheel paint i could get for the spray gun that would make it look better than with rattle can, or are the nozles on the wurth cans relly good?
        • 318daily
          • 507
          i have a question about this.
          Do you normally unmount the tires to do this? or simply mask off the tires and just paint
          the inside and oustide of the rim with the tire still mounted ?
          • e30evolution
            West Werks
            • 1888
            well since i have access to a tire changer i can take the tires off... but if you want you could paint them with the tires on... it would make prepping them harder and in a paint job 90 percent is in the prep work
            • UNHCLL
              • 8790
              I painted mine with the tires on.
              A good idea is to at least remove the wheel weights when painting. I forgot to do this.... :evil:
              Würth's spray cans are fine. Your finger will go numb and weak from holding down the nozzle though.
              Below the radar...
              • e30evolution
                West Werks
                • 1888
                i was thinking as much.... tomorrow ima go to R and R my local body shop and ask what they use to refinish wheels.... i would much rather use a paint gun if possible.... but thanks for all of your input
                • mgold
                  • 709
                  What about curb rash?
                  For those of you who have repainted with Würth, did you have any curb rash to contend with? If so how did you address it? Dremel to smooth it or what?
                  • Digitalwave
                    is a poseur
                    • 6299
                    Re: What about curb rash?
                    Dremel rocks.
                    RISING EDGE
                    • mgold
                      • 709
                      I know Dremel's rock, but do you use that to clean up curb damage?
                      • Digitalwave
                        is a poseur
                        • 6299
                        That is what I meant.
                        RISING EDGE
                        • mgold
                          • 709
                          That's what I thought...Thanks!
                          • M-technik-3
                            • 18946
                            Simple file, a flat fine and a flat bastard file. Followed up with sand paper. Practice makes perfect.
                            • grk325
                              • 178
                              sand blast your rims
                              that what i did with mine
                              easier way to get rid of your curb rash
