What is the correct offset for an M-Technic vert?
  • danalyse
    • Apr 2009
    • 153
    Looking to buy some wheels for my M-Technic convertible. It is my understanding that this model came with 15" wheels unlike most E30s that came with 14" wheels. What is the proper offset required. How much leeway is there.
  • Philo
    Ich esse kleine Kinder
    • 3334
    ?For reals?
    -tim
    Originally posted by Jordan
    I like the stance
    • E30SPDFRK
      • 5716
      same as a normal e30
      you can go et20-30 pretty easily depending on the wheel width
      Byron
      Leichtbau
      • daniel
        • 6703
        i'm pretty sure the wheels were the same 14 inch weaves, except painted white for a white car.
        http://instagram.com/dslovn.drives
        • Teaguer
          • Sep 2004
          • 6167
          Wrong.
          You are thinking of the lame chick cars that are the all white '92 Mtech "appearance package" cars.
          The true Mtech verts were all '91's and do indeed have 15" basketweaves.
          • daniel
            • 6703
            Originally posted by Teaguer
            Wrong.
            yep, that's what i was thinking of.
            • danalyse
              • Apr 2009
              • 153
              Wheel offset
              So if my wheels are 7" what would be the minimum offset.
                • 34847
                you could do ET20 no problem
                remember offset is related to wheel width, the wider the wheels the lower offset you generally need.
                • reelizmpro
                  • 9558
                  Wrong.
                  LOL. You just know chicks were all over those when they came out huh? Could explain why so many were automatic. He has a true M Technic that came with 15x7 ET24 "euroweaves".
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • danalyse
                    • Apr 2009
                    • 153
                    Finally a straight answer
                    Bought some 15" wheels for my true M-Technic vert that had an offset of 18. with some passengers in the rear the tires, when going over a mild bump in the road, would hit the inner fender area. Got my eye on some Rotas that appear to be a perfect fit. The RB pattern which I think look a bit like the old Mini Lites with the correct bore size as well as an offset of 25. Thanks all.
                    • reelizmpro
                      • 9558
                      Post some pics bro. I never get tired of Sterling silver especially M Techs.
                      88 M3 - LACHSSILBER
                      • Philo
                        • 3334
                        et 18 doesn't become a problem until you get to 9" wide wheels. Even then, not much. What is the full specs on the wheels/tires/suspension?
                        -tim
                        I like the stance
