Hartge wheels - centercaps
Not quite sure I want to put a set screw in mine. Do you have a set mocked up with a cap on them?Comment
When Jack uses words like exact and perfectly positioned, he's not exaggerating. He's a perfectionist. I saw these in person and they are high quality pieces, you won't be disappointed.I finally have had some made up. Pictures are of the original 5 (1 as pattern). They are cnc machined & fit perfect. They are made out of billet aluminum rounds. The face has the exact concave machining as the original & the outlined/raised center is the exact size for the logo. The bolt hole is perfectly positioned. I am waiting on the logo to be finished which should not be long.sigpic
January 2012 COTMComment
The part is not what I'm concerned over, I just dont want to be drilling my Hartge's for set screws. Next question, are you including a rubber seal or a plastic washer to prevent metal to metal wear? IE rubbing or debris like sand that gets in there?Comment
There is a guy in Washington who makes them forgot the name maybe he'll chime in. Can I see the way your set screw is in the wheel please.Comment
Any of these caps still available?sigpic
1986 "C2 2.7 Alpina" Sedan
1987 325ic Black Vert
http://www.r3vlimited.com/board/showthread.php?t=170548Comment
