how wide of tires can stock weaves take?
  • mkcman17
    • Jul 2010
    • 8240
    looking to pick up some rims from a forum member but he says he's got 225s on them and that seems way too stretched out but they look alright. what's the deal with that? okay or no no?
    mike
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • Apps
    • 175
    I had 225/50/14 on my weaves for a bit as autocross tires. They were Toyo RA1's and were a bit more harsh then the stock tire size but nothing unmanageable...and for whats it's worth I thought they looked fantastic...not too much bubble but about as wide as you can go stock.
    • mkcman17
      • Jul 2010
      • 8240
      cool. i guess i'll go for it then. thanks for the advice!
      • 2002maniac
        • 4260
        225 is bulged, but works fine.
        • JGood
          • Jan 2004
          • 7959
          I had 225/50/14 v710's on stock weaves, they wouldn't clear the front strut housing. Looks like you'd need an 8mm or so spacer.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
            • 34847
            as long as it's a race tire, the sidewalls are stiff enough that it really doesn't matter. 225/50-14 hoosiers on basketweaves are super light and a lot of fun.
            I think you only need a 5mm spacer up front though
            • Apps
              • 175
              Interesting I never needed any spacers with the Toyo's
                • 34847
                well just because it says it's a 225 doesn't mean it's actually 225mm at it's widest
                • JGood
                  • Jan 2004
                  • 7959
                  v710's and Hoosiers run wider then RA-1's. The manufacturers reported widths are 8.9 for the RA-1 vs. 9.1 for the v710 and 9.4 for the A6 (that's all on a 7" wheel). 1/2 inch diff between the RA-1 and R6 = 13mm, 6.5mm in each direction. That's why you need the 5mm spacer.
