Kosei 16x7.5, what offset and tires
  • bimmerm5
    • Sep 2004
    • 4
    My car has H&R sports and Koni ajustables. I want to go with the kosei k1's, but I'am not sure which offset to specify so that I don't have to run spacers. (et22 or et32) I also want to run avs100's, what the best all around size? (rubbing and spacers taken into account)
    Thanks
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    think of it this way. 32 is too far in, and you cant get 5 or 8mm spacers in hubcentric.
    22 is a little bit further out, but a good fender rolling should be all you need. if it were me, i'd do 22mm offset, and throw on some T1-S in 225/45R16
      • 34844
      22mm for sure. most 7.5" wide wheels for E30s are in the 20mm range, so you'll be fine with 22mm.
      • bimmerm5
        • Sep 2004
        • 4
        8) thanks
        • Longboardmtk
          • Mar 2004
          • 167
          Dont mean to jack your thread, but i've got another question.
          I'm going with Kosei k1's in the 16x7.5et22 to replace the wheels i have on there now. The tires on my current wheels are 205/45-16, and have about 60% tread left. If i ran these tires on the K1's would they be way to stetched out? or would they get me through the summer. I guess i could sell the borbet's i have now with the tires on them and get new ones, but if these tires will work for the summer i'd probabally just do that. Thanks
          Kev
            • 34844
            205s are fine on a 7.5" wheel, but the 45 profile is too short. 215/45 or 205/50 would be better.
