alignments
  • zandi
    • Apr 2004
    • 602
    alignments
    so I was in glendale the other day after buying some parts at BMA and i was wondering how much the local shop wanted for an alignment....$180, that sounds like a load of shit to me, he said everything is complicated and different because I put lowering springs in my car, around how much does it cost for an alignment and where should I go looking for a good place to do it?
    Also, if i get an alignment I can change the tires and still have my alignment as good correct? would only need to balance the tires?
    • 34847
    lol.. it's no different because of the lowering springs. the only thing you can adjust is toe anyway. find a shop that don't have their heads up their ass.
    and yes you can change tires without getting an alignment.
    • zandi
      • Apr 2004
      • 602
      so anyways found a good guy today, 30 bucks...but he said he couldnt align it to 100% because i have the car lowered(h&r springs), he said he adjusted the toe in and can get it aligned 70%, i just hope it made a difference
      i still have a shaky ride
      • decay
        • 5637
        like nando said, toe is the only thing that's adjustable on a stock e30 suspension.
        if you're still shaky after getting an alignment, you either have a wheel out of balance (most likely a front one), or one or more very worn bushings. sounds like urethane time to me.
        past:
        1989 325is (learner shitbox)
        1986 325e (turbo dorito)
        1991 318ic (5-lug ITB)
        1985 323i baur
        current:
