17X7 ASA AR1
  • silversleeper
    • Mar 2005
    • 2032
    17X7 ASA AR1
    I like how these look. According to Tirerack, these are for a VW Corrado, but they have the same bolt pattern as our cars. Offset is a bit high I think, at +38, but I think it will do fine. Tell me what you guys think. With the fitment and spacing issues. I dont know enough about all that.
    They look nice, and are cheap. Thats all I want. I will be mounting 225 Michelin Pilot Sport PS2s on it.
    Claus Luthe is my hero.
  • seqo
    • Jan 2005
    • 53
    Can't answer your questions, sorry... but I just wanted to say that that is a sexy wheel right there.
    How much?
    • decay
      • 5637
      i would go with the h&r 15mm spacers; 23mm offset on a 7" wheel is pretty close to ideal.
      got mine here:
      http://www.livermoreperformance.com/...pacers.html#HR
      past:
      1989 325is (learner shitbox)
      1986 325e (turbo dorito)
      1991 318ic (5-lug ITB)
      1985 323i baur
      current:
      • B3ND3R
        • Apr 2005
        • 71
        Thanks for posting this, I had pretty much the same question on those wheels.
        I hate spacers, though. The ASA website doesn't list that wheel in a 17x7 4x100, but tirerack does. I dunno why.
        ASA's site says:
        14x5 et38
        14x5 et44
        15x5.5 et38
        16x7 et38
        all in 4x100.
        p00p. Is there another wheel w/ a similiar black look AND w/ the right offset?
        • enercity
          • May 2005
          • 348
          I was thinking of getting these, and still want to, but a little expensive for me right now....i think. I dunno. I could run them without spacers on my ix though. :D
          • vr4boy
            • 282
            i just installed those on my 92ic e30 mtech pkg and i really like them-attractive and pretty light-i have 17 x 8 front and 17 x 9 rears in the e30 m3 offset-i recently finished my e30 m3 5 lug swap and chose those wheels...want to post a pic but not too sure how... :(
            • DEV0 E30
              • Oct 2004
              • 8904
              Get it hosted somewhere.
              photobucket.com
              imageshack.com
              Pretty much just google for "free image host".
              Then put it like this inside of the [img] tags.
              Code:
              [img]http://blue-helix.com/e30/gallery/05//mar/images/center.jpg[/img]
              • enercity
                • May 2005
                • 348
                yeah, post a picture please. :D
                • Digitalwave
                  is a poseur
                  • 6300
                  If they are indeed 4x100, a 15mm spacer would be ideal. But you should make sure the center bore is big enough as well. E30's hubs are 57.1mm.
                  RISING EDGE
                  • silversleeper
                    • Mar 2005
                    • 2032
                    i figured the center bore for our cars, but have not been able to find the centerbore of those rims. if anything, hubcentric rings should be able to handle that?
                    • Digitalwave
                      is a poseur
                      • 6300
                      Yes, but only if the center bore is larger than 57mm. If they are smaller, you can't use them.
                      RISING EDGE
                      • silversleeper
                        • Mar 2005
                        • 2032
                        i figured that much. thanks for the info.
                        i called tirerack, but the guy i spoke with knew nothing of the rim. i need to check out the main asa site.
                        • e30evolution
                          West Werks
                          • 1888
                          most aftermarket wheels have very large centerbores.... this wheel will have a 73mm or something like that i think
                          http://www.westwerksauto.com
                            • 34847
                            yeah, but idealy you'd want a 7" wheel with a 30mm offset for the ix.
                            • vr4boy
                              • 282
                              pic of ic w/ asa ar1
                              sorry for the late posting but here's a pic of my ic w/ the asa ar1 in 17 x9 rear/17 x8 front
                              [/img]http://img.photobucket.com/albums/v345/vr4boy/Picture.jpg
