anything lighter than the enkei rfp1 in 15x7?
  • Kershaw
    • 11822
    im not a huge fan of the +35 offset that the enkei rfp1 comes with in 15x7 4x100. but they are 9.8lbs and $179 @ goodwin racing right now. also not a huge fan of putting japanese rims on a german car. even though i am a huuuge fan of this rim.
    i hate kosei k1s. im looking for new rims for ix. not opposed to 16" rims as long as they are around 12lbs.
    im lookin to run a 215 tire all around.
    AWD > RWD
  • bimmerteck
    • 762
    What's your budget?
      • 34847
      ET35 will work fine for an ix
      but what kind of 215's can you get in a 15" size that are OEM diameter? I'd think 225/50s would be better, no?
      • KenC
        King of Kegstands
        • 14396
        Tr c1
        Originally posted by Gruelius
        • Kershaw
          • 11822
          Originally posted by bimmerteck
          What's your budget?
          ideally $600. the rpf1s are already over that.
          but i could spend a good bit ($1500...?) if you happen to show me a good looking rim that weighs 10lbs and the offset is between 25 and 35.
          tr c1 in 15x7 is around 13.1lbs. they are et30 though. but ehh...
          AWD > RWD
            • 34847
            Originally posted by KenC
            Tr c1
            offset too low for the ix and anything wider than a 205, and even that will rub with H&R sports.
              • 34847
              the 949 6UL's are about 11lbs but I think they bumped the offset higher in the 15x7 to ET42
              • bimmerteck
                • 762
                There aren't many options in that range BBS had a set of 15x7 RGF on clearance last week but it looks like someone snatched them up already.
                • Kershaw
                  • 11822
                  forgot about 949 racing.
                  their 15x7 is +36, 11.3lbs. 15x7.5, +36, 11.4lbs. and 15x8, +36, 12.3lbs.
                  i think 15x7.5 is a solid option. decent looking rim too.
                  open to more options though.
                  AWD > RWD
                    • 34847
                    you can fit 235s on an ix with the 6UL :p
                    • Kershaw
                      • 11822
                      i wanted 215s, because i am going to be using this car as a DDer. driving about 70 miles a day. wider tires = worse mpg.
                      i might even go back to 205s.
                      AWD > RWD
                        • 34847
                        I just don't think there are really any decent tires in a 215. 205 or 225 are much more common sizes.
                        • z31maniac
                          • 17566
                          I'd imagine not having your tires properly inflated would make a bigger difference in mpg than running a 225/50 over a 215 or 205, not to mention, still the most important factor is likely to be the compound.
                          www.gutenparts.com
                          • MisterMiniS
                            • 397
                            Give these a thought
                            I am about to purchase a set of these in 15x8 for autox, but the 15x7's are light! 11.3 lbs! It does have the +36 offset, but I feel a great option compared to the RPF1 for cost/weight comparison.
                            http://949racing.com/15x7-6ul-black.aspx
                            1989 325i Alpine White
                            69 STX
                            • Kershaw
                              • 11822
                              yeah, i hear you. a set of 6ul weighs 6lbs more than the enkei rpf1, but at $200 cheaper a set it definitely compares.
                              and i think they'll look better on e30s than the enkei rpf1.
                              AWD > RWD
