16x9 fitment
  • ill4noreason
    • 2710
    Originally posted by shEck3lls0
    Kinda wish I bought these before you. Oh well. Still have a set.... or we can trade and you can run 16x7.5 up front and give me two of the 16x9s.... that way you wont have to run spacers or stretch the fenders like crazy.
    I don't wanna get rid of my 16x9's I am looking for a couple extras actually.
    Originally posted by devon.818
    ^^^^ do it!
    staggared would be sweet!
    Staggered looks horrible imo especially when you have a nice deep dish...
    I will roll my fenders b4 I stagger my wheels
    My Multi car part out. Need a part? Pm me...
    http://www.r3vlimited.com/board/showthread.php?t=193051
    Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
    http://www.r3vlimited.com/board/showthread.php?t=215044
    Have you done business with me? If so leave me feedback here...
    http://www.r3vlimited.com/board/showthread.php?t=188307
    • shEck3lls0
      • Jan 2011
      • 1154
      Dang. Shot in the dark. Haha, was kinda joking anyway. Will look sick once you get em all mounted and such. Post pics once it's all done. Good luck and give me a call if you need any help. mine are 16x7.5 et 35. And in case you wanna grab some for backup i might be selling them. Hows the m50?
      1989 Alpine 325is 2dr m50 swapped
      Build Thread:
      Current ongoing build. Check it out!
      1991 318is 4dr rallycross
      Rallycross Build Thread.
      1991 Alpine 318is coupe - sold
      • ill4noreason
        • 2710
        M50 is good man. I may pick yours up if I can't find any other 16x9's. Hows the m42 rebuild? If you need any help let me know...
        • shEck3lls0
          • Jan 2011
          • 1154
          It's good. Shop will be done it this week. Also have my skidplate and sparco evo2 in as well. New wheels should be in this week as well(16x9 et15). Ordering the rest of what i need tomorrow once I get the specs from the shop. Hopefully going back together starting next weekend. This upcoming week should be a good week.
          and I forget, ordering my GC conversion kit too.
          Build Thread:
          • McGyver
            • 4595
            Hey, what suspension are you running? I just went 5-lug in the rear to run a 16x9 et20 wheel, and from the test mount i thought i was gonna poke. I'm glad you put pictures up so i didnt exchange them!
            Also, how much did you have to roll the fenders in the rear? or is that un-rolled?
            • CabrioPunk
              • 1451
              Who is doing fender work locally?
              • ill4noreason
                • 2710
                H&R Race springs on bilstien sports. No fender rolled at all no spacer in the rear neither. Up front will be a challenge as I don't wanna poke out to far ( looks weird to me). So whatever smallest spacer will work I'm gonna use then just get the back spaced out to match... I don't think I need the fenders rolled. Seems to clear fine only thing that rubbed was the shock housing... now I have to actually drive the car with all 4 wheels mounted to be 100%
                • McGyver
                  • 4595
                  That's interesting cuz on my 89 very with the same setup the 16x9 poked half an inch and the 16x7.5 rubbed. I am e36 318ti in the rear though.
                  • psyber_0ptix
                    • 904
                    im on 16x8 et23, ti rears, no rub?
                    245/35r16 though
                    edit: nevermind, i'm an asshole. it had a tiny bit of rubbing so a mild fender roll cured it. totally forgot about that
                    Originally posted by FredK
                    However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                    My year in Germany
                    Feedback
                    • McGyver
                      • 4595
                      I am also on coupe h&r race, so maybe a little sag cuz a vert is heavier? And I was running 205-45-16 on a 16x7.5 wheel and it rubbed. A mild roll should cure it though.
                      • einstein57
                        • Jun 2007
                        • 10780
                        For the fronts you'll probably need a 5mm spacer to clear the strut housing. The rears you'll want to roll a little or else you may scrape on driveways. You can get away with tapping it with a delrin malled and a heat gun. I'd also recomment removing the rear spring pad and running e90 front hats. 215/40's create a lot of wheel gap.
                        www.gecoils.com
                        • ill4noreason
                          • 2710
                          what offset wheel?
                          • ill4noreason
                            • 2710
                            Good call man! I will do... Thanks
                            • McGyver
                              • 4595
                              Originally posted by ill4noreason
                              what offset wheel?
                              Both sets of wheels were et20. I returned the 16x9 wheels and am not running 16x7.5 et20 with 205-45-16 and the fronts look like they will fit perfect without a spacer or a roll because im on e36m3 front stuff.
                              I might also have been rubbing a little because i had a tool box, floor jack, stands, and a bunch of random heavy parts in my trunk.
                              • ill4noreason
                                • 2710
                                yea my trunk is empty besides factory toolkit, jack and lug nut wrench... so maybe that is why yours rubbed.
