Rubbing with Apex ARC-8
  • evoe46m3
    • Mar 2006
    • 70
    Sorry if this has been asked but I searched for an answer and couldn't find anything. Those of you running ARC-8s what size tire do you run and with what suspension/camber settings ? I was thinking of getting 235/40 17 and was thinking I would need to run some negative camber and probably have to roll the inner fenders.
    • 37829
    Most people run the 235/40 tires. You'll just need a fender roll.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • evoe46m3
      • Mar 2006
      • 70
      Anyone else ?
      • Mfever
        • May 2007
        • 1058
        ive got my fenders rolled... im running 215/40s and they are not rubbing whatsoever. once they wear out i will run 235/40s with ease.
        • evoe46m3
          • Mar 2006
          • 70
          sweet. What suspension/ camber settings are you running ?
          • kalib0y
            • Dec 2004
            • 3620
            you will need a fender roll for sure. I am running 235/40/17 all around
            95 7.1L 16V E36 M3
            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
            LIKE my Facebook Page! CLICK HERE
            • Beej '86 325es
              • 2639
              Do you guys have issues with rubbing against the front wheel well liners when turning?
              I'm trying to figure out if my issue is because of the 235 tires or the fact that I retrofitted plastic bumpers and wheel well liners.
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • R3Z3N
                • Jan 2011
                • 3056
                ^^^ Yes, I have rubbing in the wheel well on 235/40/17 due to the diameter.(17x8.5 et40 w/ 12mm spacer up front) Am only losing the last 1/8th turn of the steering wheel though. No problems with the fenders otherwise. I am running -3.5º camber up front with this size fronts however. Going to probably give myself more clearance by cutting and fabbing a larger rear part of the front fender well.
                • Beej '86 325es
                  • 2639
                  That's odd, mine rub on the front of the wheel well.
                  Are you running a 5-lug setup?
                  -Brandon
                  '86 325es S50
                  For sale:
                  • R3Z3N
                    • Jan 2011
                    • 3056
                    Yes, I run a 5 lug setup. Caster is 10º as well for reference. I do get some rub in the front, but it's only annoying when in reverse ;-)
                    • Beej '86 325es
                      • 2639
                      I'm reviving this thread. Here's a photo of how far I can turn the wheel just before I start to rub...not much:
                      -Brandon
                      '86 325es S50
                      For sale:
                      • Wild Ride
                        • Apr 2008
                        • 739
                        I trimmed my inner liners with holes by the brake duct for clearance when turning.
