O.Z. Futura
  • russll5951
    • Nov 2008
    • 86
    O.Z. Futura
    Just wondering who is running O.Z. Futuras? Just bought some and can't wait to get them. Was also curious what tires people were using? Thanks!
  • Blackout
    • Apr 2011
    • 4130
    What are your wheel specs?
    You better have coil-overs.
    You need to slam the car basically, to pull off futuras.
    Stretched tires.
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • russll5951
      • Nov 2008
      • 86
      Front: 16x8,5 ET24 57,1 4x100
      Rear: 16x9,0 ET18 57,1 4x100
      I was hoping to see some other e30s with them so I could see the different set ups.
      • Blackout
        • Apr 2011
        • 4130
        Dude, there are shit loads of them in Norway.
        Start here > www.felgen-garage.de
        set primary language as english and check out the show cars in gallery.
        U will see cars that are running 17x10 in the rear, LOL.
        » PARTS FOR SALE
        • russll5951
          • Nov 2008
          • 86
          I have looked longingly at that site a lot lol. I just want to talk to people that have them and see what set-ups they are running.
          • russll5951
            • Nov 2008
            • 86
            So am I the only one running these in the states?
            • DTM190
              • Nov 2008
              • 1107
              I have 17x8.5 et28 with 215/45-17
              There are a few guys in the US with them, I am sure they will post up in time
              Originally posted by der affe
              first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
              if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
              • russll5951
                • Nov 2008
                • 86
                are you running spacers? I was told i may need 20mm spacers for the front.
                • DTM190
                  • Nov 2008
                  • 1107
                  No spacers but im on E30 M3 suspension and brakes front and rear
                  • russll5951
                    • Nov 2008
                    • 86
                    I was told I would have to run 20mm spacers up front. Is that true? If so could someone explain to me why?
                    • phreshkid
                      • 4655
                      Because in the front, you need to get down to about a et15 with a 9 inch rim. Because you are running an 8.5 inch rim, you might be ok to go with a little thinner spacer. Not sure the exact theory behind this but from what I've read and learned, this seems to be the case. Without that spacer, you will be rubbing all kinds of stuff. wheel to strut housing, wheel to caliper, etc.
                      • Ant_e30
                        • 292
                        The rear inner lip of the rim may contact the spring or strut and the wheel spoke face may hit the brake caliper. For this reason you need to space them out.
                        It does depend on wheel design though. You get more clearance with an 8.5 so maybe go on the wheel offset calculator and that will tell you how much more or less inner clearance you'll have compared to 9" +10
                        • Blackout
                          • Apr 2011
                          • 4130
                          Dude, ET24 in the front is not that bad. You can run a 5mm spacer if you want.
                          I have mounted Kosei K1 17 inch with ET35 offset and they made slight contact with the strut. I only needed 5mm spacer to fix the issue but i used 15mm to bring the offset down to ET20.
                          Since your offset is ET24, i would say get 8 or 10mm spacer. And you will be running sretched tires. With 20 mm spacer, your offset is going to be ET4. Turns ur e30 into a Jeep wrangler.
                          Or you could mount the wheel without spacers and take a guess at what thickness spacer you will need to clear the strut and brakes. Always try fitting before buying spacers or tires.
                          » PARTS FOR SALE
                          • DTM190
                            • Nov 2008
                            • 1107
                            Too true, I would have ended up with spacers I didnt need if I believed everything I had read.
                            • airkhin
                              • 593
                              i have some futura's on my //m. but im curious as well to what tires sizes people are running... im trying to figure out if 215/45-17 will be too tall for the front, currently stock height, and just looking for some daily driver tires. main concern is to not rub... im running 17x8.5 et 13 all around,
