Style 5 fitment general Q's
  • Todd Black 88
    • Oct 2007
    • 3449
    #46
    Originally posted by 914fan
    I have a question. I can get a set of E38 Style 5's for 175 locally. I am not finding anyone Locally that will redrill. I would like to swap to a 5 lug but that is not in the picture right now.
    Can you use these with adapters like e30Rob makes? Anyone have pics with these on the car with a 20MM adapter?
    I am not a fan of adapters but if you have to use a spacer anyway I might as well look at an adapter.
    Thanks
    Phillip
    Not without fender work.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Wishno87
      • 6025
      #47
      Originally posted by ethrtyiS
      you can run adapters. order some 18mm/20mm and be ready to roll and pull fenders.
      Pretty much tried this. No pulling needed. Not even a roll unless your really low then maybe a slight roll in the back. I was surprised. You need something like a 205/40 or 205/45 though.
      • ethrtyiS
        • 8147
        #48
        i had to roll and pull my fenders up front on stock bottle caps. hehe
        '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
        my feedback thread
        • Wishno87
          • 6025
          #49
          I see what you did there :shifty
          • EtirtyEssFity
            • Aug 2011
            • 20
            #50
            Originally posted by Blackout
            1. Get the tires ethrtyIS recommended.
            2. Mount the wheels on the car and analyze (measure the gap/clearance) how much further out you want to bring them.
            3. Buy spacers accordingly.
            If you are on a budget, I recommend Ichiba Spacers off of ebay, they are hubcentric, perfect fit and machined aluminum. Get extended lugs from EASmotorsports. $2.50 a Lug. Call them if you are not sure of what size lugs you need, they will assist.
            If you got a fat wallet, just get H&R spacer kit that comes with the right size lugs.
            Oh, let me school you on tire sizes.
            For instance, In size 205/50/16:
            205mm= Width of the tire
            50mm= Profile size (side wall. Higher the number, taller the wall and equally opposite for lower number)
            16inch = Wheel diameter
            This is not quite correct. In a 205/50/16 tire the 50 is an aspect ratio of the tire width (in this example 205mm) to come up with a sidewall height.
            Given the above, then the 50 would be 50% of 205 or .50x205=102.5
            So lets change the tire size and see how the ratio would differ with the same aspect ratio:
            A 225/50/16 would be:
            225mm cross width
            .50x225 (this is were the difference is) would = 112.5mm sidewall. So your sidewall with a 225 tire is higher than a 205 tire with the same aspect ratio.
            and 16inch = Wheel diameter
            Make sense?
            • DatUtahGuy
              • Jan 2007
              • 3146
              #51
              IT IS IMPOSSIBLE, DON'T EVEN TRY IT DUDE, seriously just won't work.
              YOUTUBE: AR Perez
              If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
              • phreshkid
                • 4655
                #52
                So, did the OP have his wheels redrilled for $120 at that place in San Diego? Can anyone confirm this or possibly the quality of work that is being done?
                • Blackout
                  • Apr 2011
                  • 4130
                  #53
                  Yes, he did. Quality was ok. I went there too. I would not go there again.
                  They redrilled them and pressed steel inserts into the new holes and even that was not done right. They could have done a better job but they really did not give a shit.
                  In my opinion, he did a super lousy job on my friend's perfect set of BBS style5 wheels. I would recommend LAX wheels.
                  » PARTS FOR SALE
                  » TRANSACTION FEEDBACK
                  • e30slidewayz
                    • 813
                    #54
                    Question... will 8mm spacers clear the front calipers? Can't seem to find a straight answer. I know 10mm clears, but can you get away with 8mm without having to shave the calipers?
                    Edit: having 10mm spacers machined for me as I type
