15" basketweaves on a 318i how?
  • kansas-ix
    • Jan 2004
    • 1600
    I want to put 15" baskets on a 91 318i, do I need spacers? Or do they bolt up?
    E30 325ix 62k
  • golde30
    • 11464
    are they offa IX? if so u will have clearance issues, and they will look ghey....IX= et41? euro 15" weaves = et24.
    IG: @Baye30
    • kansas-ix
      • Jan 2004
      • 1600
      IX so I will look ghey but I won't r3v b/c of bald tires.
      whats the offset on regular e30's?
      E30 325ix 62k
      • golde30
        • 11464
        IG: @Baye30
        • kansas-ix
          • Jan 2004
          • 1600
          SO basically I will rub in the front fender wells is the drift I'm getting is that correct?
          E30 325ix 62k
          • Mystikal
            Wheel Fitment Expert
            • 9602
            If they're iX weaves, you need tiny spacers in the front (literally 5mm will be safe) and nothing in the rear to mount on a RWD E30. Not many people seem to realize that. Just keep the tires to 205's.
            • golde30
              • 11464
              i was under the impression that on a lowered non IX they would rub the struts due to the high offset and camber of the wheel... :?:
              IG: @Baye30
              • kansas-ix
                • Jan 2004
                • 1600
                Non lowered 4x4 318i
                so where to get the 5mm spacers?
                so wait to mount until find spacers, can I find any tommorrow?
                E30 325ix 62k
                • Brew
                  • 3060
                  Wheels don't have camber...
                  And there isn't a huge offset difference between ix's and 2WD e30s. 2WD 14" baskets are et35, and I believe 15" ix baskets are et45.
                  '91 318is
                  • kansas-ix
                    • Jan 2004
                    • 1600
                    So will they mount up or do I need spacers or should I just go out to the car right now and find out?
                    E30 325ix 62k
                    • Axxe
                      • Aug 2004
                      • 3355
                      Keep it slideways!!
                      • kansas-ix
                        • Jan 2004
                        • 1600
                        So is H&R the only place to get 5mm spacers, so I need to throw down $50 to get the IX rims on the car, that is fine, but is there a cheaper alternative, it seems like you could fabricate them for less then that.
                        E30 325ix 62k
                          • 34844
                          ix wheels are ET41, regular E30 15" weaves are 24mm.
                          there's a 17mm difference. you would need a 15mm spacer to put it in about the right place. also, 5mm spacers are not hubcentric. if you're going to bother with spacers, just get the right ones (15mm at least). Otherwise you will certainly rub the struts with the ix wheels, even on the ix there is only a few mm of clearance. it will also look awful being so far inside the fenders (unless you get the proper spacers).
                          ix weaves are also 7" wide (not 6.5"), and ET41 ;)
                          although 14" weaves fit perfectly on the ix..
                          • Mystikal
                            • 9602
                            iX weaves with 5mm spacers fill out the fenders exactly the same as iS weaves, down to the mm. Not exactly super-aggressive, but enough for snows or something (what I was interested in).
                              • 34844
                              except they make horrible snow wheels, just ask the ix guys. the weave part fills with snow and the wheels get unbalanced, causing horrible vibrations. they also bend easily..
