Ronal LS Tires
  • Reddog30
    • Aug 2005
    • 17
    Ronal LS Tires
    I'm getting a set of Ronal LS's (sometime) in the future, and I'm wondering what the best size would be. I DID do a search, and saw that some people seemed to say 205/50/15, but more went with 225/50/15. However, some people mentioned that the 225 tires might rub a little, which doesn't sound too good to me. Is this true, and how big of an issue is it?
    Btw, I have H&R Sport springs, if that matters. And the tires I'm leaning towards right now are Michelin Pilot Exalto PE2.
    Thanks.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    That tire isn't made in a 225/50, so there goes that idea.
    Best compromise: 215/50/15 BFG G-Force Sport. Try a 225/50/15 BFG if you want to take the slight chance it'll rub the front strut, no one has tried it yet.
    The only reason to run a 205/50 is to use either of the crazy 200-treadwear (i.e. don't expect more than 10k out of) Falken RT-615 or Hankook R-S2. That size is too small, but those tires are worth it if you wanna go all out.
    • Reddog30
      • Aug 2005
      • 17
      I'm pretty sure it is. At least thats what I thought the tire rack said.
      http://www.tirerack.com/tires/Sizes....lot+Exalto+PE2
      6th one down?
      • Mystikal
        • 9602
        New size. Nice.
        Just looked at the spec sheet, that tire is the red-flag 9.4" wide on a 7.5" rim. That is the exact width of the BFG KD's, and those rub too much to drive the car at all.
        Just FYI, the BFG G-Force 225/50 is 9.3" wide, so far I don't know anyone who has tried them. I think it may just be enough to fit, and if no one gets around to attempting it I'll do it my damn self in the spring.
        • Reddog30
          • Aug 2005
          • 17
          Ok great thanks. So the BFG G-Force Sport are good. What else? (I'm trying to make a list of ones to look at)
          • Victell
            • 1081
            I'm running 225 bfg g-force sports on LS. Does not rub the strut. But other places...
            • Reddog30
              • Aug 2005
              • 17
              Actually, do you think the 215 g-sports would rub? They seem to be the best tires I can find that will actually fit and not rub, as far I can tell. I have heard that the side wall is somewhat soft--is this a big deal and how bad is it? Are these good overall tires?
              • Mystikal
                • 9602
                Ha! Finally!
                I can sleep at night now.
                Everyone buy 225/50/15 G-Force Sports for their Ronals now, it's an awesome tire. Just, take it easy in the rain (where you shouldn't be pushing it anyways!).
                • Digitalwave
                  is a poseur
                  • 6283
                  They do have pretty soft sidewalls but running fairly high cold PSI's can help a lot. They are great street tires.
                  RISING EDGE
                  • Brew
                    • 3060
                    I agree on the sidewall thing. I noticed a difference right away going from ES100s- feels a little less 'direct'. It does go away to a degree once you bump up the pressures a bit, and they have plenty of grip once they're warmed up. Straight line traction is excellent, too.
                    '91 318is
                    • Digitalwave
                      is a poseur
                      • 6283
                      I came from ES100's as well, and running the same tire pressures (street) there is a noticable difference under hard cornering, but that doesn't make it a bad tire.
                      RISING EDGE
                      • Jordan
                        • 12912
                        245's bitches :twisted:
                        https://mtechniqueabs.com/
                        • kylebes1
                          • May 2004
                          • 2804
                          on the front?
                          I want Ronals too. Will 225s have any chance of rubbing on GC?
                          • Nick325is
                            • 1409
                            235s all around here :D
                            Nick
                            • nickmp0wer
                              • 1427
                              im getting 225/50 toyo T1-r's for my euro weaves.
