Flush Fitment (STANCE) Thread
  • Npulver
    • Sep 2011
    • 176
    #91
    Posting my over posted POS to bump this thread. Test fitting some 17x9.5 +25 today. See how well that goes. Will post pics if its decent.
    My Build Thread Here (E30) ---> http://www.r3vlimited.com/board/showthread.php?t=240528
    And Here (2002tii) ---> http://www.r3vlimited.com/board/show...35#post3173435
    • Madhatter
      • Oct 2004
      • 966
      #92
      17x8.5 ET20 all round. 215/45R17's.
      Rear has settled a little more since driving it yesterday. 8mm spacers coming for the front to give plenty of clearance to the lower spring perches on the coil overs. Debate if I run them on the rears too and pull the guards a little.
      Just a little project im working on
      - http://www.lse30.com -
      • Ant_e30
        • 292
        #93
        ^ doesnt look like you need to pull the rears, just roll? appears to be plenty of space back there with the slightly undersize tyre
        • Npulver
          • Sep 2011
          • 176
          #94
          Looks good!
          Test fitted the 17x9.75 rims all around with 255/40's ill post pics in the morning.
          • Madhatter
            • Oct 2004
            • 966
            #95
            Its closer than it looks in that pic. They are rolled, but the tyres have such a big rim protector on them that they rub when the suspension is really compressed too. Want to put a 235/40R17 on the rear down the track though, so need just a little space.
            They are actually a little oversized.
            • Npulver
              • Sep 2011
              • 176
              #96
              heres the pics from last night, In the rears i would need a 5mm spacer and probably a 245 series tire. Was about 2mm from the strut so the tire would rub. Outside clearance was great. So i'll be running the 245/40 in the rears,
              Rears
              Fronts: Not 100% sure if this is going to fit at all. hard to tell when the 255 is such a large tire. Many things can change when you go from a 255 to a 225 up front. Not sure how much more turning clearance will be gained by doing the 225. Guess we'll have to find out. This would would requre a 10mm spacer up front along with a MUCH smaller tire the rim was touching the strut tube and the tire was hitting frame on turn in....lol
              • IRON-E
                • 16548
                #97
                There's a member and shop owner on here, his screen name is JMPAuto. He runs those wheels, on his track monster, 5 lugs, s52 powered e30.
                Don't know his specs, but homeboy's ride is hella stiff., that thing has meaty ass tires too, with a nice drop.
                @IRON-E30 aka Edwin:D
                • FunfGan
                  • Jan 2011
                  • 4958
                  #98
                  That thing looks gnarly.
                  Go here be happy!
                  Ratchet Garage e30 V8 build.
                  • MF DOOM
                    • Apr 2012
                    • 944
                    #99
                    Had these for a few months. im need tires! 17x8.25 and 17x9.75
                    • Npulver
                      • Sep 2011
                      • 176
                      #100
                      For the rears i recommend going with something like a 245/40 or 245/45 otherwise you'll have some major rubbing issues (or skinnier if you want to go stretched)
                        • 37828
                        #101
                        235/40 rear and 215/40 front, do it!
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • ckarsonkidd
                          • Jul 2011
                          • 446
                          #102
                          wow!
                          • MF DOOM
                            • Apr 2012
                            • 944
                            #103
                            was thinking 205/40 front and 225/35 rear. What do you think? not really looking for rubber band tires but i do want a nice fit
                            • Tron
                              • Apr 2011
                              • 155
                              #104
                              Ahem *look at sig* I'll dig around for more better angle pics but you get the idea.
                              • immajackuup
                                • Dec 2010
                                • 1132
                                #105
                                Iz I hellafresh?
