205/55s on e38 style 5s....need opinions
  • spiDmang
    • 3941
    hey R3v,
    So I just recently bought some e38 style 5s which are 16x8 et+23. My car is still 4 lug, so ill be running 4x100 to 5x120 adapters to run these wheels. The adapters are 20mm thick...
    My question is...what are your thoughts about running 205/55/16s on the style 5s? since im running the adapters, that will make the offset even more aggressive at et+3...
    I assume a good fender roll will be needed. But will this size fit under my fender wells, or should i be getting a smaller tire size? Only reason i am considering 205/55s is because of there price ($140 for the entire set).
    opinions/thoughts?
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • Npulver
    • Sep 2011
    • 176
    205/55 wont fit without some work. this is a 205/50 on a 16x8.25 +0 offset. Fenders rolled, but still rubs on compression without working the camber over.
    this is the front.
    i would recommend either the sizes im running or a 195 series tire to get it to fit without issues.
    My Build Thread Here (E30) ---> http://www.r3vlimited.com/board/showthread.php?t=240528
    And Here (2002tii) ---> http://www.r3vlimited.com/board/show...35#post3173435
    • rares
      • 730
      omg please post more pics... i love that stance... wooooooooooooooooow
      • spiDmang
        • 3941
        hmmmm that looks good! my wheels are 16x8 et+3....
        • Balleristic31
          • Aug 2009
          • 4198
          That looks dumb. Get some wheels that fit.
          -NICK
          • ethrtyiS
            • 8147
            205/45/16 sir.
            「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
            「my feedback thread」
            • dirk619
              • 214
              this is the front.
              any more pictures of this? been wanting this wheel.
              88' BMW 325i
              Bavauto springs
              Billy HD front/KYB rears
              Varrstoen V3 15x9 et25 10mm up front and 8mm rears.
              205/50's
              • spiDmang
                • 3941
                decided to go with 205/40s and man am i happy with that decision...the 20mm spacers really push these bitches out!!
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  In for pics...
                  Originally posted by priapism
                  Originally posted by shameson
                  • spiDmang
                    • 3941
                    As you wishhhhh....like stated before, these tires are 205/40s. final wheel fitment is 16x8 et+3
                    Rear wheel fitment...required fenders to be rolled
                    Side profile shot (dont mind the front end. i wont be dropping the front anymore until i get a skidplate...)
                    and some randoms
                    this angle sucks...need moarrr lowwzzzz:down:
                    yeee
                    • Wishno87
                      • 6025
                      You will regret the 205/40s.
                      • spiDmang
                        • 3941
                        why, because the ride becomes "harsh"? if thats the case, ive driven cars wayyyyyyy lower than this, with stiffer spring rates. ill manage;)
                        • Wishno87
                          • 6025
                          Has nothing to do with harsh. It has to do with going with such a small diameter tire. I had the same problem with 215/40s and with your 205/40s the problem will be even worse. What happens when you go with such a small diameter tire is in order for you to lower the car enough to close the wheel gap enough be satisfied with it the car is un driveable. Look at your wheel gap then look at the space between your front lip/oil pan and subtract your wheel gap distance from the space between the lip/oil pan and the ground. Once I got shortened GC housings with shortbody konis I was able to go low enough for me to be happy with my 215/40s but then realized my skid plate was an inch and a half off the ground and I could hardly get out of the driveway. Now I am looking for 205/45s/215/45s. Live and learn.
                          Edit: The wheels on my sedan in my sig came with 205/40s and they were so ridiculous I sold them off even though they were brand new and got 215/40s.
                          • spiDmang
                            • 3941
                            Great info here. Thanks wish!
                            Ill drive it around and see what happens. I was originally not gonna lower the front, but what ill most likely do is get drophats and call it a day. This is my daily, so its not gonna be perfect...reverse rake for days lol
                            • nrubenstein
                              • 3148
                              this is the front.
                              Why do people think that this looks good?
                              2002 BMW M3 Alpinweiß/Black
                              1999 323i GTS2 Alpinweiß
                              1995 M3 Dakargelb/Black
                              - S50B32/S6S420G/3.91
                              1990 325is Brilliantrot/Tan
                              1989 M3 Alpinweiß/Black
