Tire psi question
  • Gr00v3
    • 1111
    Tire psi question
    what's a good aggressive street/occasional touge/autox setup for 14" azenis... tire pressure wise
    DISCUSS!
    ________
    Angelinalove
    m42brigade
    r3v Photo Crew: Founding Member
    Guys like him are the reason I love it when people do things to their cars that are different. It just like anytime Karlo posts a thread with pics of his car, I love watching all the elitist pricks on this site shit their pants when they see an E30 that doesn't fit their standards.
  • Digitalwave
    is a poseur
    • 6290
    Occaisonal touge? You are out there every single time I talk to you :)
    RISING EDGE
    • Gr00v3
      • 1111
      just a lil bit
      /50cent
      NOBODY CARES! FUCK YOUR ASSHOLES
      ________
      Bubblers
      m42brigade
      • Bavarian3
        • 1230
        What are you running now?
        • Gr00v3
          • 1111
          the shop put it at 38 up front and 36 in the rear...
          ________
          Hawaii marijuana dispensaries
          m42brigade
            • 34839
            38-36 psi is probably not nearly enough. that's a good value for the street but you're going to shred the outer tred blocks and sidewalls your first time out.
            to start you can use chalk to check if you have enough pressure. on each tire make 3 marks on the outside sholders of the tire (making sure to go all the way to the sidewall). I'd probably start out at around 45psi (fill them cold!), you can always let some out if you have too much.
            make your autox run, and check the chalk marks. if you have rubbed all the chalk off the sidewalls, you don't have enough pressure (this is more likely to happen on the front tires). if there's still chalk left on the shoulders then you have too much. it's not exact but it can give you a good idea. also, the RWD E30s I know usually run ~4psi less in the rear.
            a better way to check is with a pyrometer, measuring the inside, outside and middle temps of the tire. probably not a good idea to buy one for occasional use but ask around, maybe somebody will be willing to take temps for you. A pyrometer can tell you a lot more about your suspension setup too, I found out that I don't have nearly enough negative camber up front (outsides of my tires were WAY hot).
            you must fill your tires when cold, because driving even a mile will warm them up to where your pressure readings are not accurate. I start out with my fronts at 48psi and after 1-2 runs the heat causes the pressure to read up 5-7psi. if you try to fill them hot by the time you get to your last tire your pressure readings will have changed and they will be all uneven.
