Question about tires size and rim size
  • BlackE30
    • Sep 2004
    • 605
    I clearly need more tire then a 205 55 15s, spins way too much under boost. I am running ronal 15x7.5 inch rims. I am thinking about running 235 _ 15s in the back, planning on rolling the fenders as well. Would that work with a 15x7.5 rim? And what sidewall height should I get.
    Thanks,
    Jeff
  • Brew
    • 3060
    Get a sticky 225/50. Maybe BFG G-Force TA KDs or Bridgestone S-03s.
    '91 318is
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      Ditto, that's what i'm getting. 225/50 G-Force. Awesome Combo.
      • BlackE30
        • Sep 2004
        • 605
        Why not like a 235 50 15? I cant spend a shit load on tires, I was gonna go with es 100s but 235 50 15 might be an awkward size, I dunno.
        • Brew
          • 3060
          Good luck finding anything in that size. I'm telling you, 225/50 BFGs.
          '91 318is
          • permit
            • Mar 2005
            • 3363
            225s would be cheaper and are plenty for a 7.5" wheel. Never buy ES100s, ever. Hell, Falkens are better than ES' and are a lot cheaper too.
              • 34834
              I bought a set of G-Force T/A KDWs in 205/55. my car isn't boosted, but I'm hoping they will live up to the reputation. I'm looking for excellent hydroplane resistance, as I'll be using them mostly in the spring and fall, with dry traction being second. I'd have gone with 225/50 but my tires are close enough to the fenders as is, and I've read the G-Forces are pretty wide.
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Neither of those works on Ronals, unfortunately. Too little strut clearance, and they run WIDE.
                G-Force Sports is about the best you can do.
                • Brew
                  • 3060
                  Since he's doing this more for straight-line traction, he could stick with 205/55's up front. 225s should fit fine out back. Yeah, I know its not ideal for handling.
                  '91 318is
                  • Mystikal
                    • 9602
                    I thought of that after the post. You're right, any 225 will fit the back.
                    • mrsleeve
                      • Mar 2005
                      • 16386
                      I just got my G-Force sports yesterday, only taken them 10-12 miles and a vast inprovment over the touring tires that came with the car. I got 225\50\15's at all four corners.
                      Originally posted by Fusion
                      William Pitt-
                      • hamann318is
                        • 3382
                        What kind of wheel?
                        The BMW 318 is back. With a vengeance.
                        • mrsleeve
                          • Mar 2005
                          • 16386
                          old MSW\OZ's 15x7 et26
                          still at stock ride height but I have a cup kit and a bunch of new suspension and brake parts on the shelf waitng for the CAB's to show up
                          William Pitt-
