why I don't like stance
  • SA E30
    • 1248
    #61
    Originally posted by ZekeTheSneak
    Grow a pair, 16x9 215/40R16 on both cars. Grip for days and daily driven. Both are on BC coilovers with Full shock travel!.
    Oh dont worry the front is coming down even more. Swapping from 200mm springs to 160mm.
    If you dont like stance then show me what your dream e30 looks like? Better yet your own.
    See Sig...
    Not sure of it's what would be called stanced (tbh, I don't even know what category my car would fit into). 17x8 235 40 up front and 245 40 in the rear, roughly 70mm down from stock, and full suspension travel. Only reason my fenders are rolled and pulled was to fit an aggressive wheel/tyre setup with my brake/suspension setup. E36 up front AP brakes, m3 rear on e46 callipers disks.
    What "name2 would I fall into??
    • ZekeTheSneak
      • 1562
      #62
      The meaning of stance is debated highly, I would say your wheels fit well but not technically stanced. What you have is a well lowered car that fits the wheels you have. If you were stanced it would be a tad lower up front and maybe a little stretch so you could turn and deter some rubbing. I am no expert I just go with what I think looks good and is still functional.
        • 34839
        #63
        you mean lower it another inch to increase bumpsteer and screw up the camber curves even more? that's pretty functional. :p
        • ZekeTheSneak
          • 1562
          #64
          Yes I do. Its not a racecar, its a 20 year old car thats fun to drive.
          • kman_e30
            • May 2007
            • 573
            #65
            whats the point of running a 9in. wide wheel if you only gonna run a 215 tire? at least go 225, i have a buddy who i drift with that runs 17x9s with a 215 on his s13. i cant understand it. besides the tire fitment your car looks dope bro!
            84 318i drift car
            04 mk4 gti 1.8t
            96 e320
            63 plymouth valiant
            • ZekeTheSneak
              • 1562
              #66
              I run a 215 so they fit in my wheel arches, a 225 is only a little wider...
              • Robotin
                • Jun 2011
                • 4471
                #67
                i would have to agree that e30's with mexi poke and insane amount of camber looks a little rediculous.... i think the square body and angled tires dont contrast well...
                but on some of the rounder newer japanese cars... they look pretty sweet.. and some of those guys those cars are their DDs... those guys have some balls to do that...
                1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                1989 325ix [zinnoberrot] $OLD
                1970 2002 [Nevada]
                Originally posted by Herr Faust Schinken
                guy must have slid into something that doesn't look like a car vs car hit
                Originally posted by ak-
                Must of slid into Rob
                • FunfGan
                  • Jan 2011
                  • 4958
                  #68
                  Just to throw it in there, every car has "stance".
                  Go here be happy!
                  Ratchet Garage e30 V8 build.
                  • ZekeTheSneak
                    • 1562
                    #69
                    I want to see some pics your guys opinion of the proper e30
                    • Jaxx_
                      • Dec 2009
                      • 1880
                      #70
                      cry about it
                      • Sagaris
                        • Sep 2009
                        • 2243
                        #71
                        This isn't a direct stab at you at all or anything you said, I just want to point out that those who are functional do not have to make such drastic measures to attain good performance.
                        R3v problem: "M20's are so slow, I need a 24V swap"
                        functional solution: remove your 23 LB BBS knockoffs for a light set of wheels,
                        ... and so forth
                        • Holland
                          • Nov 2008
                          • 7212
                          #72
                          What I like?
                          I like the form of function, especially in race cars. I like plenty of low, on a nice square setup. I can dig stance, but not all kinds. Here is a stanced car I do like:
                          Studs, plenty of front camber, enough rear camber. Yes the tires are stretched but it sits more like a race car.
                          Originally posted by DEV0 E30
                          • Stephen
                            Шлем ишака
                            • 10774
                            #73
                            I can barely turn my car ever and i have to change my wheel bearings every 5000 miles.
                            • csermonet47
                              • Jul 2009
                              • 937
                              #74
                              Man I guess I am doing it wrong ...
                              Better get some 15x7s with proper sized tires and a 24v swap so I can do poorly at autocross.
                              Are Three Vee
                              Dad Spec
                              • Stephen
                                Шлем ишака
                                • 10774
                                #75
                                You'll need 235 rcomps at least to hold on to the poorly sealed junkyard m50s earth shaking 140whp. I run 255s on my bottlecaps on the track to be safe, but thats cus im probably hitting about 200whp with my 2.7i stroker and cut belts.
