e38 style fives with adapters
  • mbonanni
    • Sep 2011
    • 6236
    #31
    Originally posted by slowe34
    I wish the 42 Draft Design adapters would happen already. Only thing Im waiting on before I pull the trigger and get these stylr 5's on my car!
    Is there a thread for these? link?
    Thanks
    • Zasz
      • 1030
      #32
      This post is to glorify your dog some more: I laughed out loud.
      Also, good luck with the wheels.
      ///Z
      1988 BMW 325 Super Eta - Elsa
      "i"CONVERSIONWARchip&3.0MAF3.73LSDBBSRSsSMILIES"is"SPOILER+LIPHOUNDSTOOTHSHORTSHIFTERPLASTICBUMPERCONVERSIONEtc.
      Sell Me Your SCHWARZ FENDERS!
      ^ Nothing you post makes any sense.
      • slowe34
        • Sep 2011
        • 206
        #33
        Thanks
        her:
        • mbonanni
          • Sep 2011
          • 6236
          #34
          Thanks! Good new is they should be done within the week.
          • Mystikal
            Wheel Fitment Expert
            • 9602
            #35
            Originally posted by e30 gangsta
            In the front or rear?
            In the past I ran a 16 by 9 et10 with a 215/45/16 and there was too much poke upfront, outback was perfect though with a roll and a pull.
            If you ran a 18mm adapter that would bring the style 5 in the front to et5.
            You think with et 5 upfront and a 205/45/16 it will rub? I don't think so. I may be wrong though.
            Rear rub. Fronts have acres of space.
            Originally posted by aje28
            +1 I would like to know this as well as I plan on buying 18mm adapters and having et 5 all around. I have a early model too so I dont know how much different the late models are.
            Shouldn't need more than a flat roll and decent springs on an early model.
            • shoguncro
              • May 2011
              • 115
              #36
              Redrilled to 5x120 then fited with adapters
              • aje28
                • 572
                #37
                Nice!, What's the final offset on it?
                • flash 23
                  • 904
                  #38
                  ^ which adapter is that?
                  • duckBoy
                    • Jul 2008
                    • 271
                    #39
                    Subscribed...
                    • george graves
                      • 19998
                      #40
                      Ummm. I must be missing something - don't those start out in life as a 5x120 wheel? no?
                      Originally posted by Matt-B
                      • d_elson0
                        • Feb 2011
                        • 242
                        #41
                        +5/+0 205/40s
                        style 5s w/adapters
                        • mbonanni
                          • Sep 2011
                          • 6236
                          #42
                          Okay there was some talk about needing to run 18mm adapters, and the draft 42 designs adapters are only 20mm at the lowest. what does this change?
                          • noE30
                            • Jun 2008
                            • 2260
                            #43
                            Your wheels will sit out an extra 2mm, which shouldn't be too noticeable really.
                            Flickr
                            @michael.colby on Instagram
                            "All he needed was a wheel in his hand and four on the road"
                            • slowe34
                              • Sep 2011
                              • 206
                              #44
                              I just ordered a set of the draft 42 adapters in 20mm form, so I should have a definitive answer in a week or so. I'll be sure to document the amount of roll that's needed for others interested.
                              • Matt-B
                                The Waffler
                                • 3856
                                #45
                                i had style 5s redrilled, to 4x100. ran a 20mm rear spacer, basically like running an adapter. Rubbed in rear only on bumps. fronts I ran an 8mm, no issue.
                                front might stick out a bit and rub, not sure
