e38 style fives with adapters
  • Dj Buttchug
    • Jun 2010
    • 7678
    Originally posted by slowe34
    So, which is it? Just from looking at were my stock wheels sit I would think the fronts would need a roll first.
    its what I said before. Fronts dont need to be pulled or rolled. On later model arches you can run a 205/45/16 with an et of 0 and still not rub.
    You will rub in the rear which is why i said you need to pull and roll.
    Im assuming the JOM setup will go just as low as my k sport setup so im giving this information based off my own experience.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • slowe34
      • Sep 2011
      • 206
      Awesome. This is what I was wanting to hear. And since Im not having a lot of luck the with local machine shops, I think I will be going this route.
      Buttchug, can we see pics of said current set up?
      • e30 gangsta
        • 3877
        Any of you guys have link to the adapters that are the thinnest?
        • slowe34
          • Sep 2011
          • 206
          e30Rob on this board has custom adapters. Search for his spacer and adapter thread.
          • tk-421
            • Sep 2011
            • 291
            I've been emailing the people at motorsport-tech and they quoted me $375 shipped for adapters with 18mm being the smallest they could do.
            1990 E30 325i sedan - Gletscherblau (280) over Indigo cloth (0271)
            • Dj Buttchug
              • Jun 2010
              • 7678
              Heres a pic from my build thread. Keep in mind this is Et0 all around 205/45/16
              With this set up I rubbed in the rear. As you can see (sorry for not close up pic) the rear quarters are not butchered or pulled much at all. Maybe an 1/8 of an inch pull plus pounding the inner pinch metal flush.
              Again, front fenders are untouched. Consider the offset change with adapters tho, If you run 20mm(Which I plan on doing) then slap a style five on it your final Et is +3. This extra positive offset will be more than enough to prevent rubbing in the rear. 18mm will more than suffice.
              Anyways thats my deal. some other guys here with early arches and different setups may have some other opinions about this...
              Ig:ryno_pzk
              • tk-421
                • Sep 2011
                • 291
                I know it's a little OT but has anyone have experience with running E39 17x8 Style 5's (et20) with 20mm adapters? I just scored a set for dirt cheap and may want to do that instead of going 5-lug.
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Id you end up with adapters do not use 205/45 (it will rub badly) or 205/40 (it doesn't leave you with much ground clearance).
                  You'll want a 195/45.
                  • e30 gangsta
                    • 3877
                    Even with a roll?
                    How about rolling and pulling the fenders?
                    • Mystikal
                      • 9602
                      With a good pull and spring rate, 205/45 will work.
                      • e30 gangsta
                        • 3877
                        In the front or rear?
                        In the past I ran a 16 by 9 et10 with a 215/45/16 and there was too much poke upfront, outback was perfect though with a roll and a pull.
                        If you ran a 18mm adapter that would bring the style 5 in the front to et5.
                        You think with et 5 upfront and a 205/45/16 it will rub? I don't think so. I may be wrong though.
                        • aje28
                          • 572
                          +1 I would like to know this as well as I plan on buying 18mm adapters and having et 5 all around. I have a early model too so I dont know how much different the late models are.
                          • ak-
                            • 12422
                            @ et5 a regular roll with anything like or above H&R race won't rub. MAYBE on hard cornering.
                            Early model = Better clearence. You're even better prepped if you want to do a 0 offset.
                            1991 325iS turbo
                            • mbonanni
                              • Sep 2011
                              • 6236
                              I am debting whether I should spend my money on a set of e38 style fives and do fill and drill/adapters or stick with my euroweaves and get them powder coated white with polished lips. It is a very hard decisison. I will be keeping p with this thread!
                              • slowe34
                                • Sep 2011
                                • 206
                                I wish the 42 Draft Design adapters would happen already. Only thing Im waiting on before I pull the trigger and get these stylr 5's on my car!
