I'm looking for relatively strong and light wheels, and Kosei's come to mind. I've heard of custom drilled blanks, but where can I find them? I'm hoping for 15x8. Any other wheels out there that can be used with no spacers or rings in this size?
15x8 or 16x8 Kosei K1's or equivalent
15X7 BLANKS ET17 SIL K1 RACING
15X7 BLANKS ET27 SIL K1 RACING
15X7 BLANKS ET38 SIL K1 RACING
15X7 BLANKS ET45 SIL K1 RACING
15X8 BLANKS ET12 SIL K1 RACING
15X8 BLANKS ET22 SIL K1 RACING
16X7.5 BLANK ET12 K1 RACING
16X7.5 BLANK ET22 K1 RACING
16X7.5 BLANK ET32 K1 RACING
16X7.5 BLANK ET43 K1 RACING
16X8.5 BLANK ET17 K1 RACING
16X8.5 BLANK ET27 K1 RACING
You gotta call them to order, and you tell them the bolt pattern and centrebore.
As for other 15x8" wheels, good luck. Most other ones that fit properly without spacers are only 7" wide or the 7.5" Ronals.
Oh, and so anyone looking for info knows, the following fit the E30 well:
16x8.5 with 245's all around :D
Seriously though, kosei's own.Last edited by Axxe; 10-27-2005, 03:08 AM.
Originally posted by rwh1138515x7 Kosei K1s. need hubcentric rings. Or get Team Dynamics which are direct fit. And lighter.
The ones you have were probably universial or ordered for a different car with a larger centrebore.
Originally posted by T.Dot E30Unless you order blanks and tell them the exact centerbore and bolt pattern. They are blank, hence no holes.
If you are in Canada, I wouldn't take Auto-X where you run without helmets serious enough to be worrying much about your competitive edge.
15x7s are cheap, easy to replace, and a good compromise.
Don't listen to Heeter, he's got a fucking hard-on for 15x7s with narrow tires.;)
Go for the 15x8s. They will work very well with 225/50s.
I think its going to be close with the et22 15x8 blanks, though. You may have to run a small spacer up front.
Anyone have any experience?'91 318is
Originally posted by BrewDon't listen to Heeter, he's got a fucking hard-on for 15x7s with narrow tires.;)
