17x10s Pics with specs
  • JeremyE30autox
    • Dec 2010
    • 404
    Originally posted by The Dark Side of Will
    But 215's on a 10" wheel makes me scratch my head.
    Agreed. 275 in my future
    Dare 2 Dream Motorsports
    • jaywood
      • Jul 2010
      • 4528
      I've yet to see it on an e30...I just know a few e90 guys who run 265 on their 10" and it's not stretched.
      • einstein57
        • Jun 2007
        • 10780
        There are plenty of e30s with 255/40/17s that don't look stretched. Thats only 10mm on each side from the ideal sized tire. I'm just afraid i won't have any grip in 1-3rd with anything less then a 275.
        www.gecoils.com
        • Pl3wA
          • 1589
          hmm, im actually in the market for 10" meatiness. i would try to run 275's on a stock fender. show me some wheels and tires to buy yooo! please keep it reasonably priced
          • FunfGan
            • Jan 2011
            • 4958
            Go here be happy!
            Ratchet Garage e30 V8 build.
            • einstein57
              • Jun 2007
              • 10780
              teaser bump
              www.gecoils.com
              • kalib0y
                • Dec 2004
                • 3620
                Originally posted by einstein57
                Pertinent post on the "E30's on 17" kicks pic's" thread
                225/35/17
                Geez this E30 is so clean!
                95 7.1L 16V E36 M3
                Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                LIKE my Facebook Page! CLICK HERE
                • Breezy
                  • Jun 2012
                  • 2
                  Can anyone point me to someone with 4x100 17x10" Brock B1 wheels? If willing to sell, I want them.
                  john.s.khalil@gmail.com
                  Text or call: 908.421.1023
                  Thanks!
                  • Mr. Burns
                    • Aug 2011
                    • 3516
                    gonna bump this up..
                    for those running a 17x10 et15..with 235/40 or 245/40 tire, what type of fenderwork was done?
                    I'm currently running 16x8 with 0 ET...allready have my fenders pulled and rolled to the max...
                    I'm about to pull the trigger on some 17x10's and am wondering if my fender will be okay as-is.
                    car is '90 vert.
                    Originally posted by flyboyx
                    i have watched my dog lick himself off a few times
                    • Killacortes
                      • 1937
                      245s dont look too bad on the 10 inch wheel. but someone should post theirs on 265/275 :D
                      r3v does not fuck around. First you get banned, then they shoot you
                      • MatRacer
                        • 562
                        I'm about to attemp to fit 255/40/17 on the rear, on 17x10 et20. I will keep you guy updated.
                        I'm just waiting on my spacers for the front...that will be on 235/40/17 on 17x8.5 final offset et20.
                        E30 now S52
                        2008 Suburban LTZ (Family and TT hauler)
                        325xiT (Sold)
                        • Mr. Burns
                          • Aug 2011
                          • 3516
                          Matracer, have you allready rolled your fender?
                          are you lowered at all?
                          • Mr. Burns
                            • Aug 2011
                            • 3516
                            back up with this...
                            searched, and getting lots of confliciting feedback.
                            who ACTUALLY has a 17x10 et14 rear setup and is running a 245/35/17 tire?
                            how much of a roll (if any at all) was required?
                            those running a 225/35/17 still needed a roll?
                            application is a 90 vert lowered 1".
                            i'm being told i need a perfect roll and incredibly stiff springs, whereas many guys here don't seem to sport these specs..
                            • MatRacer
                              • 562
                              I rolled, a lot I think, and cut a bit on the inner sheet metal of the fender and 255/40 doesn't fit at all! I tried 235/40 and I still have a bit of rubbing... I will see what I can do... I will try to cut more sheet metal inside the fender. Note that I'm doing my test fit with Toyo RA1, a tire that run pretty large, like 9'' vs 8,5'' (bidgestone RE-11) for a normal tire (data from tire rack)
                              I'm low (60mm drop) with soft spring... around 300lb/in on the rear. Should replace spring.
                              E30 now S52
                              325xiT (Sold)
                              • Tonys18t
                                • Sep 2009
                                • 943
                                with a 225/35 that runs small ( for example Falken 452 etc ) and an offset of 14 you need to roll the lip totally flat, pull as much as is possible on the lip and then shave the lip out ( in that order ). you will still have minor issues on bigger bumps and driveways.
                                If you decide to run a good degree of camber you'll be good.
                                I have a little experience fitting extreme sizes to cars ;)
                                PBMW Magazine. PVW Mag
                                Fender Rolling for dirt cheap in SoCal. Hit me up.
                                Check out my work...
                                http://www.r3vlimited.com/board/showthread.php?t=165114
