Huuuge wheel poke. Is it too much?
  • E30SPDFRK
    • 5714
    Different tires have different tread widths depending on how the manufacturer measures it, even if they're the same size. Falken 512's are the skinniest running tires you can buy, and you can use the clearance.
    Byron
    Leichtbau
    • coreyw
      • Jul 2010
      • 368
      Originally posted by mother_russia
      What was the lug pattern on those rims?
      4x100
      S52 Swap
      Shtuff For Sale
      • E30_fiend
        • Apr 2006
        • 7348
        +1 on falken 512's.
        I will only run them. Also, you will have a hard time finding a 185/45 in any size. If you do, be prepared to spend around $200 per tire.
        It really doesnt matter what size you run in the front because you wont really have any clearance issures. The rear, try getting a 205/40 falken 512 as said before.
        Taylor
        • mother_russia
          • Apr 2012
          • 421
          Originally posted by coreyw
          4x100
          There you go. I need adapters, and on top of that, my et smaller.
          Originally posted by E30_fiend
          +1 on falken 512's.
          Taylor
          Would 205/45 be a good stretch on 16x8 rims? I was thinking 195's...
          • E30_fiend
            • Apr 2006
            • 7348
            a 205/45 would be a very slight stretch. And the problem with 195s is that only a few companies make them and they all run wide which is horrible for stretch. Just go 205/40. you wont be sorry.
            205/40 on my 16x8s
            Taylor
            • Ant_e30
              • 292
              You missed the point of the comparison picture that guy posted. He was demonstrating to you how his 16x9 stuck out when just bolted onto te car in the air without tyre. It doesn't look too different to the pic of yours fitted with the adaptors.
              16x8 -7 is about 10mm more aggressive than 16x9 +15 off the top of my head
              • Jim Lepage
                • Jul 2008
                • 1138
                They will fit. I have more poke than you're gonna have with my actual setup.
                Last year picture:
                E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
