6.5 wheel diameter
  • 318isbmw
    • Nov 2005
    • 2843
    6.5 wheel diameter
    wondering about the traction w/ a 15 x 6.5 wheel. I'm hoping to autocross, is this a no go, or would they be ok traction wise with some good tires? thanks for any help.
  • Digitalwave
    is a poseur
    • 6299
    The wheel width has little to do with traction, its the tire width and tire compound that matters more. That being said, I'm not sure you can fit 225 tires on a 15x6.5" rim.
    RISING EDGE
      • 34844
      I think a 225 should fit, although it will be puffy. people put 225 r-compounds on 14" bottlecaps all the time, and they're only 6" wide.
      • Digitalwave
        is a poseur
        • 6299
        Yeah, I wasn't really sure. It may very well be possible.
        RISING EDGE
        • Jordan
          • 12916
          Aluminum has a pretty shitty coefficent of friction. You will slide all over the place with those wheels.
          https://mtechniqueabs.com/
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Throw some 205/50/15 RT-615s or R-S2s on there and you're set.
