16x9 ET6 anyone got it fitted?
  • Vivek
    attention whore/retard/bitch
    • 6167
    16x9et10 215/40. Sold them because the tire size was too small diameter-wise (among other reasons, but that definitely influenced it).
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • grippymonkey
      • Jun 2011
      • 759
      Originally posted by einstein57
      If your body guy can't get them to fit then has zero skill or no imagination. Castros are able to caress the fenders out far enough to fit negative offset 9.5" wheels with 255s
      that's what I'm saying
      people that say he isn't going to fit the offset and size he asked about and not be able to run any kind of tire width at all are crazy... fender rolling/pulling are not hard at all. It depends if you want to put in a little work to fit more tire or less tire. My fenders are barely massaged, and I run nearly this same outer rim lip to fender clearance (10" +15) with a chunky tire now.
      :D
      GRIPPY'S*GARAGE
      • Jozi
        • 244
        I'm going to see the painter this week, anyone care to elaborate on what needs to be done to fit them so I can tell him? I rather not have to come back to this after the whole car has been resprayed.
        • wakdog
          • 223
          Before I got my RS's, I was running 16x9 +15 A's with a 5mm spacer (so +10 effective) with a 225/45R16 Kumho...
          Fender lips were folded in and thats about it. Running 650lb rear springs with konis it would only scrub on the biggest of all bumps (2-3 times a week daily driven).
          90 318i M62B44 OBD1
          02 530i Touring (Airlift 3P)
          • Jozi
            • 244
            Thanks wakdog for the pics and wheel/tire/spring sizes. I suppose 4mm more might be manageable, I'm not going for a crazy low car. Yours looks just perfect the way it sits. I must look into what springs I got with my BC's!
            • 325ix
              • Aug 2009
              • 7783
              My wheels are 16x9, et18 out back and 16x8.5 et24 up front. I am running 205/40 tires up front and 215/40 out back. The first picture is with a 15mm spacer all around and the second is with 15mm up front only.
              There is a decent ammount of room like this. I think with a nice roll and maybe slight pull I could get a 225 easliy and probably a 235.
              • Jozi
                • 244
                Love them wheels are they OZ or Keskin (I can't tell the difference)? Your pretty much ET3 with the spacer, I'm getting less and less worried after the last few posts.
                • 325ix
                  • Aug 2009
                  • 7783
                  They are the OZ's, the center caps are the big difference, the keskin's don't have the ring on them.
                  • Jozi
                    • 244
                    Didn't know that! Did you widen them yourself?
                    • 325ix
                      • Aug 2009
                      • 7783
                      No sir, the PO bought them off of El Camino, I believe.
