Mini wheels?
  • 318driver
    • 1714
    Mini wheels?
    i know that mini wheels have a different center bore and would require spacers, but does anybody know of anyone who has done this? Any pics?
    90 325is
    IE stage 3s and refeshed m20....
  • LikeCDoos
    • Jan 2004
    • 2522
    i know 318daily had bbs rk replicas made for a mini on his e30.
    • LikeCDoos
      • Jan 2004
      • 2522
      there they are, i love those wheels...i'd like to try and find them in 16"
      • 318driver
        • 1714
        do you know what size spacers he uses.and how he delt with the centerbore?
        90 325is
        • LikeCDoos
          • Jan 2004
          • 2522
          It looks like he used 15mm H&R spacers...you can PM him he is on this board sometimes.
          • Kavkazia
            • 394
            What does centerbore has to do anything with spacers? I understand using spacers for high offset wheels to correct the original offset of E30 but for the bore, if Mini's center bore is bigger than E30 325/318, you can use plastic rings to match correct bore size of E30 325/318, otherwise, it wheel cause steering wheel to vibrate/shake at high speeds, from my experience.
            :D
            95' M3.
            90' 325i Turboed.
            87' 325eS Fixed.
            • Digitalwave
              is a poseur
              • 6299
              The Mini center bore is smaller.
              RISING EDGE
              • krisco
                • 180
                Yes, you definately need hubcentric rings if the centerbore isn't the same, I needed them for Koseis.
                • Brew
                  • 3060
                  Hubcentric rings will only work if the center bore of the wheel is LARGER than the hub bore of your car. So wheels designed for a direct fit to the mini, meaning no spacers or hubcentric rings, will NOT work on e30s unless you have the center bore machined to fit. I suppose you could use a big spacer to put the inner face of the wheel out past the hub of the car, but you would have major vibration problems because it would not be hubcentric.
                  '91 318is
                    • 34844
                    couldn't you make a spacer with a hub area that would fit into the mini wheel and the E30 center bore on the other side?
                    • Brew
                      • 3060
                      I suppose you could.....but I think it would be easier just to machine out the bore of the wheel a few mm's.
                      '91 318is
                      • Digitalwave
                        is a poseur
                        • 6299
                        It'd have to be a big spacer, where the lip came off of the lip from the E30's hub.
                        RISING EDGE
                        • darien28
                          • Jan 2004
                          • 240
                          it's not that hard, just ge a spacer that has the right centerbore... it'd have to be 15mm+ spacers though or else there won't be enough material to make the smaller lip.
                          machining the centerbore to fit is also a good option but make sure the shop knows what it's doing or you'll get an off-center hole... lol
                          since you'll have to use spacers anyways, might as well get wheels that come w/ larger centerbores like the standard aftermarket 72mm bores that nearly all the fwd wheels are...
                          • Digitalwave
                            is a poseur
                            • 6299
                            And be ready to pay for those custom spacers...
                            RISING EDGE
                            • 318driver
                              • 1714
                              screw it, i dont wanna get to crazy with wheels, i just want something simple. i plan on getting wheels this summer, and they have to be 16" because money is tight and i already have tires that are the right size. How much are 16in kopi's???anybody know
                              90 325is
