Adapters or Fill N Drill
  • turge
    • 2576
    I know this has been asked probably a million times, but should I fill n drill or get adapters for my 16x8 (et 23?) e38 style 5's. I'm probably going to get coils sometime in late February or March from a friend who does work for StanceWorks (more info on coils once mine is complete).
    Anyways, a little history on the wheels. They are currently black and the paint is chipped so I'm going to have em resprayed as well. That's why I want recommendations on whether or not to fill n drill (then paint), or paint and get adapters. That being said, what are some good companies that make adapters for style 5's?
    So should I get adapters or Fill N Drill? And what are the advantages / disadvantages of both options?
    Thanks guys!
    31
    Adapters
    61.29%
    19
    Fill N Drill
    38.71%
    12
  • Bimmerguy91
    • Jul 2012
    • 982
    an 18mm adapter will put the final et at 5 which would be flush. No need to fill and drill.
    • series88
      • Nov 2011
      • 1231
      adapters. Since you would want to space them out a bit anyway. Plus, you open up your world to a whole selection of wheels.
      • Vivek
        attention whore/retard/bitch
        • 6167
        If you want to tune your offsets without spacers and have the potential to use other 5 lug wheels on your car, get adapters. If you just want to run these wheels specifically and slightly increase the resale value of them, fill and drill them. You'll need to run spacers. Adaptec makes good adapters. Both will likely cost a similar amount.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • turge
          • 2576
          What style adapters would you recommend off their site?
          • ak-
            • 12422
            Fill and drill let you play with offsets considering spacers.
            Adapters don't, you're stuck with flush.
            That's all there is to know
            1991 325iS turbo
            • turge
              • 2576
              What's wrong with flush? Not like I'll be tracking the vert. lol
              • ak-
                • 12422
                Where did I say I had a problem with it?
                1991 325iS turbo
                • turge
                  • 2576
                  Guess I assumed. mah bad.
                  On another note, if I were to get coils, I could adjust camber and some other stuff as well.
                  • turge
                    • 2576
                    18mm front and rear? Looking at this site and kind-of confused on what I need to do for the wheels to fit properly.
                    Motorsport Tech is your absolute number one source for wheel adapters, wheel spacers, and hub centric rings. We manufacture the finest adapters in the world, and we do wheel polishing, chroming, powder coating, and color matching, as well as sell wheels and tires at WHOLESALE PRICES.
                    • Bimmerguy91
                      • Jul 2012
                      • 982
                      Yes 18mm front and rear most likely
                      • Jboss12
                        • 357
                        here is my car with e38 style 5's. 18mm front and 20mm rear 4-5 lug adapters. 205/45r16 tires. fenders are not rolled at all.
                        • Bimmerguy91
                          • Jul 2012
                          • 982
                          That is straight up sexy!
                          • turge
                            • 2576
                            Why did u do 20mm rears?
                            Sent from my XT907 using Tapatalk 2
                            • F34R
                              sLaughter
                              • 12385
                              Don't do with them...go with these guys! they are a vendor on this very site.
                              18 and 20mm staggered would be spot on, you mentioned no issues with flush. Just roll and pull a bit and you're done. Coilovers will allow you to tune the height to a perfect finish.
                              Instagram: @BWeissLeather
                              Current cars:
                              ~ '87 325 M30B35 swap
                              ~ '87 535
                              ~ 01 540 Msport 6spd
                              ~ '06 X5 4.8is
