325iX Wheel thoughts
    • 34844
    you won't hit the spring perch with stock diameter tires. a 17" wheel isn't any closer to the perch than a 15" - unless you went with a taller overall diameter. but 215/40 is pretty much the same as stock.
    it's the tube itself that the tire is really close to with the stock wheels.
    • litu
      • 844
      So when think at this way
      Does not when compared normal e30 (51mm suspension bars), the only difference is in front 5mm track width the difference in front.
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
        • 34844
        I'm not sure I follow - there are a lot more differences than just the track width. :)
        • litu
          • 844
          If I understand correctly that those is about the same E30 vs ix. So, if think tires/rims size almost, not stock tyres/wheels size. The only difference is that the track width of the front, but this clarified things.
          I'm sorry if I can not explain clearly :)
            • 34844
            well, the struts are more upright, and there are differences in clearance around suspension components.
            but, generally, the ix will have a higher offset. It's more than 5mm as well (I'd have to dig up my manual, it's listed in a wiki but the numbers look wrong).
            • asetliff
              • Nov 2012
              • 28
              Stock iX wheels/tires...
              15x7 +41 205/55-15
              New size:
              17x7 +35 215/40-17
              The wheels will stick out 11mm further toward the fender and 1mm closer to the shock. They will occupy the same exact space rotationally, and are within 4mm of rolling diameter. The speedometer will be off by .3mph at 60mph, which is negligent.
              I understand quite clearly the offset and wheel differences. What I want to know is, does anyone currently have some 17's on their iX and have pictures and specs on wheel/offset/tires
              • litu
                • 844
                Find information, resources and relevant links for e30world.com. This domain may be for sale.
                In there is stock rear wheel e30 1407mm and ix is 1420mm. Ok i remember wrong, but the difference is just 13mm.
                On the previous page I made a post a few pictures ix 17 inch rims
                  • 34844
                  I think that site is wrong, the rear track is different too.
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    Originally posted by Sade
                    http://e30world.com/specifications/BMW-E30-specs-table
                    That's funny, if you search my posts I've been saying for years that iX track is about 6-7mm off. Looks like it's 6.5mm.
                    • litu
                      • 844
                      But my ownersmanual says that normal 325 track width is 1407mm and is 1420mm, 13 mm is wider
                      • Mystikal
                        • 9602
                        ...per...side
                        • litu
                          • 844
                          Originally posted by Mystikal
                          ...per...side
                          Sorry 13divided by2 is 6.5mm per side
                          Yes, that is that number, as you say earlier
                          I do not know if that's right then, but hardly the owner manual Would fool
                            • 34844
                            the hub is more than 6.5mm, track width is based on the wheels/tires. So the hub sticks out more, plus the wheel is higher offset (41 - 24 = 17mm). You have to add the two together to figure out how far the 325ix hub sticks out, it's a lot more than 6.5mm.
                            The rear hubs stick out 17mm more than a standard E30 (since it has the same track width), and the front hubs stick out 23.5mm more.
                            Now you can see why I say an ET20 wheel doesn't work on an ix, because it's really ET-3.5/ET3 (front/rear) in comparison to a standard E30.
                            running an ET35 wheel on an ix is comparable to running an ET15 wheel on a standard E30, only you have the additional concern of strut and suspension clearance to deal with because everything moved out, not just the hub.
                            • litu
                              • 844
                              Thank you, this is now the right info, what i need it now.
                              This somethig i think also, nut my brains dosent work, because of incomplete data. This is now lighted up the whole thing.
                              :bow:
                              • Mystikal
                                • 9602
                                You're right, using the track figures my estimate is incorrect. But, the E30s in that chart are NA models using 14" wheels (majority being +33, so I assume that's the measurement they used). So the front hubs would be 13mm [track] + 16mm [wheels] meaning 29mm overall or 14.5mm per side. The rears stand at 0mm [track] + 16mm [wheels] meaning 16mm overall or 8mm per side.
