15x10 Rear questions
  • OrangeFiero
    • Nov 2011
    • 350
    I have accepted the challenge of trying to fit a 15x10 in the back of my e30. As i understand after some searching, if i go with 6" back spacing, i will be flush and safe of any rubbing in the inner lip. Will the inner barrel of the wheel fit? I was hoping to not poke too much and if they are not flush enough, just use spacers to fine tune fitment. Pics would help.
    John 16:33
  • Robotin
    • Jun 2011
    • 4471
    you have to run like a -10
    1989 325i SETA stroker [delphin] R3V'd 8/31/2011
    1989 325ix [zinnoberrot] $OLD
    1970 2002 [Nevada]
    Originally posted by Herr Faust Schinken
    guy must have slid into something that doesn't look like a car vs car hit
    Originally posted by ak-
    Must of slid into Rob
    • OrangeFiero
      • Nov 2011
      • 350
      What is that in back spacing? And i thought i needed to run a higher positive et or they would poke like mad.
      John 16:33
      • Pootis
        • 636
        I thought the max amount of back spacing you can run in the back is 4.5? Correct me if I'm wrong
        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
        • OrangeFiero
          • Nov 2011
          • 350
          http://www.stanceworks.com/forums/sh...ad.php?t=10611
          Oscar on this forum says hes running 5.5BS on his 15x10 but it is an early model, ive got a late... dont know if different.
          John 16:33
          • OrangeFiero
            • Nov 2011
            • 350
            On r3v: half way down page 2, white325is says hes running a 6" back spacing too.
            John 16:33
            • series88
              • Nov 2011
              • 1231
              Check with this guy. :)
              • bmwguy325is
                • May 2011
                • 1263
                If you click the link for my car in my sig I run 15x10s
                The wheels on my car a pretty much a zero offset. I run a 5mm spacer all around but that is so I can clear in the front and I want everything square.
                With the spacer the wheel sticks out about 2 inches or so.
                If that helps.....
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • wakdog
                  • 223
                  Im running 15x10 +15 BBS RS on the rear of my car, and there is about 2mm of clearance from the rear trailing arm and the inner barrel. Anything higher offset than +15 is going to hit....
                  Here is a pic of it with temporary 205/50R15s (going to go 225/45 when i get an engine back in the car....)
                  90 318i M62B44 OBD1
                  02 530i Touring (Airlift 3P)
                  • OrangeFiero
                    • Nov 2011
                    • 350
                    Thanks for the help guys! I think i know that i need to now.
                    John 16:33
