325ix Wheel Thread
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4493
    325ix Wheel Thread
    Gents n' Ladies,
    I've been searching and haven't found an IX wheel thread. So, I say we start one.
    Throw up wheel and suspension specs, and a few pictures!
    Some general info about IX wheel specs taken from another thread:
    Originally posted by nando
    the hub is more than 6.5mm, track width is based on the wheels/tires. So the hub sticks out more, plus the wheel is higher offset (41 - 24 = 17mm). You have to add the two together to figure out how far the 325ix hub sticks out, it's a lot more than 6.5mm.
    The rear hubs stick out 17mm more than a standard E30 (since it has the same track width), and the front hubs stick out 23.5mm more.
    Now you can see why I say an ET20 wheel doesn't work on an ix, because it's really ET-3.5/ET3 (front/rear) in comparison to a standard E30.
    running an ET35 wheel on an ix is comparable to running an ET15 wheel on a standard E30, only you have the additional concern of strut and suspension clearance to deal with because everything moved out, not just the hub.
