offset question
  • der affe
    Technical
    • Dec 2005
    • 8452
    offset question
    what wheel spacers do i need to run "+45" offset wheels on my 91 325i?
    they are 16X7 4 on 100, they are off of my a-2 jetta, and came off of a 96 civic before that.
    thanks,
    greg
  • der affe
    Technical
    • Dec 2005
    • 8452
    oh and i am running 205/55-16 tyres and have H&R springs and Bilstein sports if that makes a difference
    • asubimmer
      • 6482
      20mm i think
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        20mm all around will do fine. That's what I ran on mine with a +43 offset. Cleared the calipers and no fender/shock rubbing
        The stock offset is +35mm for E30 (the bottlecaps)
        http://www.1010tires.com/WheelOffsetCalculator.asp
        (put in current specs, and new specs, and it will tell u if it fits. Pretty handy)
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • der affe
          Technical
          • Dec 2005
          • 8452
          Dank!!!
          • Mystikal
            Wheel Fitment Expert
            • 9602
            20-25mm.
            BTW, those tires won't work. You'll rub everything.
            • Digitalwave
              is a poseur
              • 6300
              Yeah tires are enormous. 25mm spacers would be ideal but aren't as practical as 20mm (which will still work).
              RISING EDGE
              • Garageaholic
                • Dec 2005
                • 5204
                I think for 25, they arent' spacers anymore, they become adapters... which have lug studs on them built in.. I may be wrong, and maybe some manufacturers make 25mm spacers, but i wanted to make sure just for the hell of it
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  i am running these tyres now with almost no issues, except a slight rub in the front when turned full lock and going through a big dip. other wise no prob. i think the wheels are the same offset that are on it now, they came with the car, and the kid has a big stack of cheep spacers....scarrrrry.
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    and i am a body man, i can always just roll the fenders, if there is a lip problem
                    • Digitalwave
                      is a poseur
                      • 6300
                      Rolling the fenders doesn't save you from rubbing on the fender lines and the sway bar.
                      RISING EDGE
                      • Mystikal
                        • 9602
                        There are 25mm spacers and 25mm adaptors. Adaptors go all the way down to 15mm, just so you know.
                        And I'm shocked that one can run 205/55/16 tires and not completely shred the plastic fender liners. I've seen smaller tires do it.
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          i don't know how or what he did, (there were michelin 205/55-16's on it when i bought it, i liked the ride quality, so i replaced them with some kumho's) but there is no rub issues, and everything seems intact so.......maybe a magic wand?????? i also took a closer look at the spacers he used and they look like about a 10 or 15 mm spacer on each wheel all the way around. i just don't really like the wheels they are a n enki big spoke bbs ish knock off. the wheels off my a-2 jetta looked great on it (boxy car) and the only other time i have seen these wheels was actualy on a e-30 way back when my friend had them on his civic, they are pretty light and are made by kosi for senica 16x7.5 i have 5 of them, and since they are circia 1995 i doubt i'll see them on another car. my friend paid a grand just to have them polished (stupid i know but it was a show car, and that kind of stuff was his bag) i will prob try to fit them this weekend, and see what happens
