Compomotive Challenge: Can this be fixed?
  • 3toedshewie
    • Aug 2011
    • 364
    Problem: Retro classic set of 16 x ? compomotives :love: has a "plug" put into them, glue has been used :crazy: :roll:
    Pictures are attached. Any ideas? :?: :?: :?: :?: :?:
    all together now
    the repair (front rim)
    up close:
    from the back:
    Lieben Sie Schlangen ?
  • Old city bimmer
    • Jun 2014
    • 1114
    Yes- that can be fixed. Good wheel repair shop can fix that.
    Sent from my iPad using Tapatalk
    323i MTEC1
    Z3 coupe
    E60 M5
    • 3toedshewie
      • Aug 2011
      • 364
      Thanks Old City bimmer! know a good wheel repair shop? Had a bad experience with wheelfixit, and they're considered to be good down here.
      • AndrewBird
        The Mad Scientist
        • 11898
        Assuming the centers aren't magnesium, it can be filled with weld and re-drilled. I kinda wonder if they are magnesium, hence the glued in insert, or maybe it's a just a shitty repair.
        • 3toedshewie
          • Aug 2011
          • 364
          my guess is just a shitty repair. not sure if Compomotive ever made any magnesium rims. thanks andrewbird
          • 3toedshewie
            • Aug 2011
            • 364
            Update: Any advice in picking the right shop to do it? are there better methods than others? are there tools that make it more accurate or stronger? is there a website where I can learn about the right way a shop should do this?
            • 3toedshewie
              • Aug 2011
              • 364
              bump
              • 3toedshewie
                • Aug 2011
                • 364
                bump
                • redlightpete
                  • Mar 2012
                  • 264
                  You're probably fine just running 4 bolts/nuts. Works for the spec e30/pro3 crowd (granted the position of their 4 is a little more optimized).
                  • 3toedshewie
                    • Aug 2011
                    • 364
                    uh, does any body else think thats safe?
                    • Van Westervelt
                      • 9365
                      No.
                      • 3toedshewie
                        • Aug 2011
                        • 364
                        bump, anybody know where I can get replacement barrels for these? are there any other brands that fit these wheels?
