Having brake clearance issues with e38 style 5s
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Okay dudes I got a set of style 5s redrilled and the rears fit awesome but I'm having some issues with the front. The anti rattle clip seems to be interfering with the back of the wheel. This is with 5mm spacers it doesn't seem like it will require much to them fit. I just need to know where to remove some material
    88 325is Five Speed
    Lachssilber
  • ak-
    • 12422
    You can shave down the part on the brake where it's rubbing without ill effect.
    Why not run a bigger spacer? Your doesn't seem that low so you should be fine on an 8" x et23
    1991 325iS turbo
      • Feb 2012
      • 3580
      Okay I just didn't want to remove a bit more metal there and have my brakes explode. One of my friends is seeing if he has an 8mm spacer set around
      88 325is Five Speed
      Lachssilber
        • Feb 2012
        • 3580
        8mm spacers didn't do anything still rubs
        88 325is Five Speed
        Lachssilber
        • ak-
          • 12422
          You can cut that bracket off completely and still be fine.
          Stack the 5mm on the 8mm if you're lugs are long enough.
          1991 325iS turbo
            • Feb 2012
            • 3580
            I think the 8mm will fit. I had to thin out part of the bracket a bit but that bar is still about 10mm thick so I think it will be fine. I haft to do the same to the other side tomorrow.
            88 325is Five Speed
            Lachssilber
            • Eric
              • 5142
              I'd manually measure your offset, my guess is the machinist took a bit off the backside to make a nice smooth finish. You might get away with a 10 or 12mm spacers just fine.
              • f4tj0n
                • May 2013
                • 411
                I had the same issue and used 12mm spacers to make it work.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Just a note, 10mm spacers won't work properly on a an e30. They aren't thick enough to be hubcentric, but are too thick to allow enough hub to stick into the wheel to locate it. There are 12mm hubcentric spacers, but 15mm is more common. Stacking your 5mm and 8mm spacers is a bad idea because the wheel will not locate on the hub, only via the lugs and will cause balancing issues.
                    • Feb 2012
                    • 3580
                    Motorsport hardware has some spacers that are 10 mm and have hub extensions. I have 57mm studs so I should be fine. I'm gonna try clamping the two 5mms I have together and putting the car on the ground tomorrow to see if that will fit.
                    88 325is Five Speed
                    Lachssilber
                      • Feb 2012
                      • 3580
                      So this is where it sits with 10mm it seems like it clears fine at least going up and down my driveway and turning the wheels back and forth
                      88 325is Five Speed
                      Lachssilber
                      • Eric
                        • 5142
                        Turning the wheel and going up and down won't change the relationship between the wheel and the brake caliper bracket that is fixed to the strut.
                          • Feb 2012
                          • 3580
                          Yeah i get that, but i was concerned it wouldn't clear the arches with the 10mm spacers, thats what i was trying to see if i would have rubbing issues.
                          88 325is Five Speed
                          Lachssilber
                          • jayamasaki79
                            • Oct 2014
                            • 342
                            completley removing or shaving the bracket down wil have no effect on the caliper ?
                            Im kinda going through the same issues (but not style 5's)
                            the back of the rim is hitting the same exact caliper bracket, but im not sure i can use spacers as the rim is already sticking out. Cutting off or shaving the bracket down would sove my problem, but was worried about its function.
                            • Kershaw
                              • 11822
                              some calipers do not have that little bracket at all. but you modify your calipers at your own risk, obviously.
                              AWD > RWD
