15 or 16s? opinions wanted.
  • Stanley Rockafella
    • Aug 2011
    • 4062
    I'd go 15's just because
    1. Cheaper tires
    2. slightly better fuel economy
    3. quieter ride
    4. easier on the suspension components
    • g.ruff561
      • 1268
      Me, Varg, AbsorbantNut all live in the same general area and run basically the same setup. 16x8 / 9 with 225/45/16 is about as good as you can get. The tires are out there and the ability to minimize the wheel to fender gab is a plus. My ET is 15 on all 4 corners. No rub lock to lock. No spacers. I'm on HR sport up front and coils in the rear. Rear coils keep the car from dropping on acceleration and rubbing fenders on speed bumps.
      Agressive look and meaty rubber. Price difference between 15 and 16 inch rubber is about $15 to $25. IJS.
      • danix
        • Jan 2014
        • 151
        If you went with the ESM-002R for an E30, what's the correct offset? Are spacers needed?
        I've given up trying to find decent 14" tires for the original wheels, these look decent but I am unsure about quality and fit.
        1988 325iC SOLD
        1985 524td 49k
        • straight6pwr
          • Sep 2004
          • 3450
          1. Cheaper tires
          3. quieter ride
          1. true
          2. not necessarily true, depends on wheel weight, not size.
          3. ? what does wheel size have to do with noise?
          4. although theoretically true, i couldn't feel a softness difference in sidewall between a 15" and 16" on an e30. between a 14" and 16", yes. between a 17" and anything else, yes. a 16" still has lots of sidewall for soaking up bumps. tire brand/style comes into play here too - if you get a 15" tire with stiff sidewalls, it will be harsher than a 16" tire with soft sidewalls. if the OP runs stupid undersized stretchy tires, it doesnt matter what the wheel size is, the sidewall will be tiny.
          i'd say performance and ride quality are pretty near the same for 15"/16", it comes down to aesthetics and tire availability.
          • e30onBBSs
            • Dec 2014
            • 1347
            16's usually look better, but a nicely done 15" setup can look just as good.
            BMW tech
            Umass Amherst
            05 wrx sti
            • bruner
              • Aug 2013
              • 402
              16s FTW
              90 M3 brilliantrot/schwarz
              90 M5 brilliantrot/schwarz
              87 325 alpinweiss/houndstooth (building)
              90 735i/5 islandgrün-metallic/schwarz (daily)
              87 Foxbody Notch 5.0 5spd SSP (other daily)
              71 F-250 4x4 390 4spd
              • digger
                • Nov 2005
                • 6196
                16" can ride better than 15" depending on the tyre
                • Streichholzschächtelchen
                  • Jan 2009
                  • 1670
                  15s if you live in pothole city, more sidewall.
                  Jah bless! :pimp:
                  • alas
                    • Oct 2015
                    • 291
                    I think 16's look the best. Not too big like 17". 15's need dish to look good IMO.
                    That said I just purchased 15" RS's [emoji28]
                    I think you have a bit more options with sizes and clearance with 16" too vs. 15".
                    Not sure what engine you're running but I think a tire wider than 215 is a bit much even for a 325i.
                    205's are more fun [emoji854]...if you're into that kind of thing.
                    -E
                    -ALaS
                    • alas
                      • Oct 2015
                      • 291
                      Random Q... Your name, does it mean little matchbox? Lol. Please explain!
                      -ALaS
                      • Jordih
                        • Apr 2013
                        • 18
                        Unless you are slammed or want baloon tires, I'd go with 16's. Love mine on 205/45s.
                        ESM001 8" ET20
                        Billy sports, IE Stage III springs, drop hats, no springs pads upfront.
                        $500 '84 325e All Year Beater
                        Gunmetal Purple
                        390,000 KM's
