disadvantages of wheel spacers
  • vic_325
    • 264
    i cant find any direct fit wheels local, so im thinking of just getting the popular offset wheels and using spacers. but first i need to know the effects of spacers.
  • Dave
    E30 RAT
    • 11675
    You'll need longer bolts and/or studs
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • vic_325
      • 264
      is that about it? they wont change the feel of the ride or anything?
        • 34844
        make sure they are hubcentric. no, they wouldn't affect your ride, unless they weren't hubcentric and the wheel wasn't centered correctly.
        • erik325i
          • Jan 2005
          • 3567
          They will add a little bit of weight.
          They won't kill you though. Just make sure that they are hubcentric, wheelcentric, and you get a long stud kit.
          -Erik
          • vic_325
            • 264
            ok sounds good, thanks
            • ACHTUNG
              • May 2005
              • 2397
              Since there is added weight (stress), your wheel bearings might wear more quickly.
              1989 US E30 Cammed S52
              Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
              • straight6pwr
                • Sep 2004
                • 3450
                a whole .25 lbs per corner on top of the 30+ lbs wheel/tire weight wont make a difference.
                • JGood
                  • Jan 2004
                  • 7959
                  I've been running 5mm spacers for nearly 6 years. Not a single problem. My car rides smooth as butter, no vibrations. No damaged bearings, seals, clips, tabs, widgets or anything.
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • kowalski
                    • Jan 2005
                    • 1791
                    what about a damaged flux capacitor?
                    • 325iCabrio
                      • Jun 2006
                      • 485
                      I've had tire places loose my spacers a couple of times when I've gone in for tire rotations. I have no idea how they lose them, but they do. Other than that I've had no problems.
                      1988 325ic Automatic
