Will these fit my e30 ok?
  • Nygdup
    • Jul 2006
    • 418
    15" Rota Grids 4x100 et38 W/Toyo T1-S 195/50.
    Will these fit my e30 ok? Not sure how the et works.
  • Mike325
    • Mar 2006
    • 3685
    That et is for a FWD car. Our cars have a 20 et i believe. You will need spacers, which is common and not a problem to do. Not sure on the tire though.
    Originally posted by Kershaw
    • Nygdup
      • Jul 2006
      • 418
      Tire rack shows some BBS wheels with 38mm offsets. You sure I would need spacers?
      Tire size should be just about right. My current ones are 195/60 r14
      • BUDNUNTA
        • Apr 2005
        • 996
        Most higher offset wheels from tire rack come with spacers, lugs and rings if needed for e30 fitment. 15" wheels with optimum offset, around et20 can run 225s with rolling.
        Search DigitalWave to find some info on his old grids and setup.
        Hunter
        We're out there in here.
        • Nygdup
          • Jul 2006
          • 418
          Bought the wheels. They fit and there is no rubbing or any other problems related to the ride. Obviously, though, they need the spacers to be pushed back out in the wheel wells just for looks. I take it I need a 18mm spacer? Also, where is the best place to find spacers reasonably priced?
            • 34847
            195/50 tires are way too damn small.
            • Nygdup
              • Jul 2006
              • 418
              The car was on 195/60 14's when I bought it. And I can always buy new tires.
              • e30frosh
                • Dec 2004
                • 2170
                I can get you the spacers you need. I have one set left from a GB that need to be turned to your specs. Tires? I would go for a 215/50 for a decent fit. 225/50 are some good meat for traction, not in wet or snow tho.
                Every day I wake up we drink a lot of coffee and watch the CNN
                Every day I wake up to a bowl of clover honey and let the locusts fly in.
                Lobsterbacks attack the town again
                Wrap all my things in aluminum
                Beams of darkness streak across the sky
                Pink rays from the ancient satellite
                Every time I look out my window same three dogs looking back at me.
                Every time I open my windows cranes fly in to terrorize me.
                • Nygdup
                  • Jul 2006
                  • 418
                  Well, the car is a daily driver so I don't need the extra width. Most of my driving is interstate at that.
                  Let me know a cost on those spacers and lets see what we can work out.
                  -Rich
                  • JoeMadoo
                    • 936
                    I run 225/50s on 15x7 et20 rims. I think it looks nice and beefy, there is no rubbing at all, even with lowering springs.
                    '86 E30
                    '05 E53 X5
                    '72 Firebird
                    '10 Prius
                    '03 Tundra
                    • e30frosh
                      • Dec 2004
                      • 2170
                      Spacers are all aluminum spun on a cnc lathe. I could get 'em to you for 225 shipped. You would have to get longer wheel bolts tho, I picked mine up from www.parts4vws.com
                        • 37834
                        A 10-15mm spacer would be ideal for you.
                        Also, the correct size tire would be 205/55 or 225/50. Your current size is tiny.
                        Grover Beach, California
                        BimmerHeads.com
                        • 2002maniac
                          • 4260
                          Did you ever state the width of these wheels? Any offset information is useless without knowing the wheel width.
                          Offset is the distance of the hub surface from the centerline of the wheel.
                          • Nygdup
                            • Jul 2006
                            • 418
                            I'm not home to double check, but I think they are 7.5"
                            • DRFlickner
                              • Jan 2007
                              • 8
                              They're 6.5" for sure. I've sold a ton of these wheels.
