Absolute Lightest 15x7 E30 wheel that does NOT require spacers?
  • Ben Carufel
    • Jun 2004
    • 5248
    What is it? What is the lightest track wheel I can buy for an E30 that doesn't require spacers of any sort?
    Hmm?
  • rwh11385
    lance_entities
    • 18403
    Hubcentric rings matter? They were always a PAIN on my 240.
      • 34835
      you could probably make BBS RGF 15x7s work. ET33, ~10lbs. but not cheap!
      • Ben Carufel
        • Jun 2004
        • 5248
        ET33 sounds like it's on the edge of needing a spacer.
        Volk TE37's are 9lbs in 15x7 fitment, but they are an ET43.
        • Ben Carufel
          • Jun 2004
          • 5248
          I wouldn't be against them, but wheels that don't need them would be cool.
            • 34835
            why are you so against spacers anyway? if this is for a track car, you're probably running studs anyway, so spacers aren't a big deal.
            • AdamF 88iS
              • 2051
              15x7 Kosei K1s are I believe ET27 and in the 13lb range IIRC.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • fretburnr
                • Jan 2005
                • 1496
                i'm guessing unsprung weight, but i'd like to know as well
                Jay
                • Axxe
                  • Aug 2004
                  • 3355
                  Why 15x7?? Why not go 15x8 so that 225's sit better? I doubt you are going to be racing competitively, so wheel weight doesn't really matter that much, so long as they are around 15lbs or less
                  Keep it slideways!!
                  • Brew
                    • 3060
                    Buy my BBS RG's: 12lbs, forged, 15x7, et25, hubcentric, sexy.
                    '91 318is
                    • E30 Racer
                      • Nov 2004
                      • 427
                      Try Kodiak. Not cheap, but they'll be about the lightest a wheel can safely be made.
                      Garrick
                      1989 325is
                      DSP #72
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        http://www.1010tires.com/wheel.asp?w...#37;2E0+%2D+GM
                        10.5lbs and forged. A bit pricey though.
                        I want a set for my MG...
                        • E30 Racer
                          • Nov 2004
                          • 427
                          Originally posted by NitroRustlerDriver
                          http://www.1010tires.com/wheel.asp?w...e+1%2E0+%2D+GM
                          Not bad, but when you factor another additional cost and weight (1-1.5 lbs) for the spacers needed for non-ix applications, they become a bit less appealing...
                          Garrick
                          1989 325is
                          DSP #72
                          • Ray Smoodiver
                            • Jun 2004
                            • 8809
                            Alpinas?
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              What is the factory offset for an e30? I thought it was et35? I guess the width of the wheel changes that though...
