This is a sticky topic.
  • Stephen
    Шлем ишака
    • 10774
    #1636
    Originally posted by Mystikal
    That's a stock basketweave. You tell me.
    And you're...starting. :p
    Well the wheel isn't a stock weave, but same size. i guess i just assumed weaves were +20?
    Edit: oh yeah they are +30. Well cool then.
    • Smash9002
      • Apr 2008
      • 96
      #1637
      For an e36 m3 5-lug conversion, im looking at 17x7.5 offset 41 front and 17x8 rear style 32's. can anyone tell me if they will fit?
      -Doug
      • brn2ply7
        • 301
        #1638
        Thanks!
        89 325i parts car
        90 325i in progress
        ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
        --tryng to join the schwarz army one day at a time--sigpic
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #1639
          Yup, they'll fit. 215/40/17 tires are the safe bet.
          • evilnickwong
            • Aug 2007
            • 302
            #1640
            Quick question guys, I'm running throwing stars rims on my 1991 E30 4dr, they're 16x7.5 ET20. Currently I'm using 205/50 front and 215/50 rear (which are too big).
            I'm thinking of going down to 205/45 front+rear for the next change, but I'm not sure if that's too low profile? 205/50 looks abit fat to me and I thought 205/45 might fit better, but I also wanna keep my speedo accurate. Some say 205/45, and some say 205/50, so I'm not sure now.
            • brn2ply7
              • 301
              #1641
              For easiest fitment: 5.25" front, 6" rear. This equals ET19 and ET25, respectively.
              For poke: 4.5" (ET0) front, 5.25" (ET6) rear. This will require a bit of fender rolling.
              Could i get away with 15x8's all around with 4.25" of back spacing?
              89 325i parts car
              90 325i in progress
              • Mystikal
                • 9602
                #1642
                205/50/16 is the stock diameter. Even with that your speedometer reads high, so going smaller will only make it worse.
                205/45/16 is still entirely acceptable though, as long as you know the dial is going to be like 8% high.
                • Mystikal
                  • 9602
                  #1643
                  ET-6? Nope.
                  • evilnickwong
                    • Aug 2007
                    • 302
                    #1644
                    Meaning it will show 108 kmh when I'm really only doing 100kmh? Ok noted. :)
                    Reason I want 205/45 is because I don't like the thick look on the 205/50, + my car is lowered on H&Rs and the 205/50s get pretty close to the inner wall on full lock.
                    • matt_vo
                      • Mar 2007
                      • 30
                      #1645
                      Winter tires
                      Another quick question.
                      I have 195 65 R14 winter tires on now. Could I put 195 60 R14 tires on? What difference would it make?
                      Thanks, Matt
                      • Borat
                        • Jan 2005
                        • 494
                        #1646
                        they will fit fine, as above speedo will read slightly fast
                        • cbouchez
                          • May 2007
                          • 2789
                          #1647
                          ok,
                          maybe you guys know. I'm just about ready to put my winter tires back on. I boght them about 5 years ago when I had my GLI.
                          Any one know what type of wheels these are?
                          specs 4x100
                          BMW (RONAL )
                          I know they are pretty bad looking but that is why I like them!
                          Follow my IG @bouchezphotography
                          • Mystikal
                            • 9602
                            #1648
                            Thanks, Matt
                            Just a slightly high reading speedo, and some more fender gap. Nothing else worth noting.
                            • Jim Lepage
                              • Jul 2008
                              • 1138
                              #1649
                              I'm looking for 16x5,5 et45 steel wheels. Will they fit ?
                              E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
                              • Mystikal
                                • 9602
                                #1650
                                With around 1cm to spare, yeah. No problem at all.
