	This is a sticky topic.
 E30 now S52
 2008 Suburban LTZ (Family and TT hauler)
 325xiT (Sold)
 sigpicComment
 Guess I should have posted here:
 Running 16x9 Borbet Ts (et15) with 215/40 R16 tires.
 10mm spacer on front
 20mm spacer on rear
 AGRESSIVELY LOWERED.
 I'm about to fix the rear geometry by replacing my subframe with one that has the toe/camber kit welded on. I want to get a little more life out of my tires, so I'll probably fix the camber a bit. I'm afraid that if I do that, the 20 mm spacer will be too much and I will have some fender interference (already rolled). There is some interference already when really loaded up, but that's not very often.
 So my question is: What size spacer should I get? Is it as simple as taking 5mm out and I'll have that much more clearance? Or is that enough? I keep meaning to look under the car and see how much room I have on the inside, don't want to clear interference one way, and start some the other... (How much of a spacer do I NEED on the rear to run the 16x9 et15s?) If I have a smaller spacer, could I maybe have more tire in the rear? Not crazy about running staggered, but it would be fun to try for a bit, I think.
 I'm going to get custom spacers made (again) so I want to know what to tell Fred.
 Slicktop City!Comment
 If one were to run 16x9 wheels. (offset not sure but maybe 20), would 195/50/16 tires fit to give it a stretched look or would it not be wide enough to fit? My friend ordered some 16x9 wheels and wants a stretched look. I have 16x7 remembers with 195/50 and looking to get rid of them for some 205s or 215s so my friend may buy my current tires off of me if they fit. ThanksComment
 I have exactly the same setup as you mutty -- 17" BBS RCs w/ET35 and a 10mm H&R spacer -- and my 215/40/R17 Michelin PE2s fit perfectly on H&R/Bilstein Sports. No rolling. I do however seem to have a bit of fender gap (about the size of a man's fist) in the front. The rears however have no issues. Sorry I've got no pics, I'll see if I can snap a pic if you want one though.
 I tried to fit them without spacers as a test, they rubbed in the front without the spacers.Comment
 no, too low. you could cut the shit out of the rear fender flares and run a 205/40-17, that might work. but if you want to run a 215/40-17 or even a 225 stick closer to ET30. it will still fit flush with the wider tire.Comment
 Thanks for the info. Another ones bitten the dust. Now off to TMS to get studs/nuts.I have exactly the same setup as you mutty -- 17" BBS RCs w/ET35 and a 10mm H&R spacer -- and my 215/40/R17 Michelin PE2s fit perfectly on H&R/Bilstein Sports. No rolling. I do however seem to have a bit of fender gap (about the size of a man's fist) in the front. The rears however have no issues. Sorry I've got no pics, I'll see if I can snap a pic if you want one though.
 I tried to fit them without spacers as a test, they rubbed in the front without the spacers.  Comment
 Reducing your negative camber will definitely also reduce your fender clearance.Guess I should have posted here:
 20mm spacer on rear
 http://www.r3vlimited.com/board/showthread.php?t=108169
 Your rear wheel will actually clear the inside without any spacer at all by over a cm. You can back down the spacer to any size you want, or even none at all.
 Even with no spacer, I still recommend 215/40 as the widest, unless there is some moderate/heavy fender work in the cars.Comment
 Absolutely insane stretch going on there. It's theoretically possible, but you will likely have trouble finding anywhere that would mount such a setup together. I wouldn't do it.If one were to run 16x9 wheels. (offset not sure but maybe 20), would 195/50/16 tires fit to give it a stretched look or would it not be wide enough to fit? My friend ordered some 16x9 wheels and wants a stretched look. I have 16x7 remembers with 195/50 and looking to get rid of them for some 205s or 215s so my friend may buy my current tires off of me if they fit. ThanksComment
 Both tires are too wide for the wheels. You can do a 235/40/17 (just barely, given the width of the wheel), but that's it really. With rolled fender you'll be fine.
 That said, I know I've seen it done by another member on here (245s on a 17x7.5). I still can't recommend it though, that's some serious "over-tiring".Comment
 Just curious why my 15X7 Borbet type bs (et35) rims with 205/55 rub the inside front struts badly. Do i need spacers for them, if so what size do you think, also do i need smaller tires for them would that help out.. They bolt right up just rub really bad..Cheers in advanceComment
