	This is a sticky topic.
 So my brother wrecked his 94 jetta last week, and I have the opportunity to get some 17x8 Konig monsoons. Now I have no idea what the offset is, but, with the wheels strait, the front wheels rub against the strut tower. So, my question to you is, what sixe spacer am I going to need in order for these to not rub?
 Thanks
 NickComment
 Depends on what offset the wheels are.So my brother wrecked his 94 jetta last week, and I have the opportunity to get some 17x8 Konig monsoons. Now I have no idea what the offset is, but, with the wheels strait, the front wheels rub against the strut tower. So, my question to you is, what sixe spacer am I going to need in order for these to not rub?
 Thanks
 NickComment
 see, that's the problem. My brother bought the car with the wheels on them, so no info was givin about the besides that they were 17s. Is there a way that I could measure the offset?Comment
 What is the largest tire size to fit on an ix.. Assuming the car has Euroweeves.. Im moving up to the mountain and will be towing a single snowmobile(less than 1,000 lbs)..I'm also looking for good traction in a little deeper snow.. anyways any input would be greatly appreciated..
 -BrandonsigpicComment
 here is a tough one, 16x11 et28 on a 318ti rear 5 lug. Is there any tire out there that might work with these wheels? :twisted:///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
 attn: bbs rs owners need advice on tire fitment on a 8x16f & 9x16r
 hello i hope you could help me on my tires?
 i have a rs 8x16 offset is 15 fr. and 9x16 offset is 0(zero)
 now i would like to now what tire size should i put. i already roll my fenders. i have a 1991 vert please guide me on this tanxs alot!
 please if you have the same wheel size and offset please post some pix!
 and tanx matt for the suggestionsigpicComment
 My wheel fit question
 I just bought a used set of 17 inch ASA AR1 wheels. They were originally on an E36 M3 so the ET is 40mm. Fronts are 8" wide, backs are 9" wide. I intend on installing a 35 profile tire, probably 215's and 235's respectively. I need some advice. My car is slightly lowered, not slammed. I'm just running a set of H&R springs. My fenders are NOT rolled.
 In a perfect world, I would just buy a set of 20mm spacers and everything would be fine. I've been reading as much as I can find and it seems that people use some pretty odd sized spacers to make wheels fit where they didn't originally belong. Should I buy the tires I think should fit on the wheels and then start working to determine the spacer I need? Or should I buy a set of 20mm spacers and then choose tires based on clearance?
 I guess it is sort of a, "which came first, the chicken or the egg?" type issue.
 Any advice regarding tire size or anything else related to this would really be appreciated.
 ThanksComment
 If they hit the strut and they worked on a Dub, they are probably ET35 or so. Go for 15mm spacers.Comment
 You don't want large tires in the snow, you want the opposite. Smaller contact patch = more weight per sq area = better traction.What is the largest tire size to fit on an ix.. Assuming the car has Euroweeves.. Im moving up to the mountain and will be towing a single snowmobile(less than 1,000 lbs)..I'm also looking for good traction in a little deeper snow.. anyways any input would be greatly appreciated..
 -Brandon
 Go 185/65/15 for optimal snow traction.Comment
