This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2446
    Originally posted by stinkydriverx
    yoo jay,
    Its me for about the 100th time.
    I just bought some vw fitment kosei k1's in 17x7.5 et 35 with 205/40's on them. I dont know what the hub bore size is( i cant find the specs ANYWHERE) They came off a sentra as far as i know. My question isssss.
    I was thinking a 10mm hubcentric spacer would be enough.
    But i have no idea where to find one. any help?
    EDIT: so i have figured out that places like americas tire can measure the hub bore of my new wheel (kosei k1). my guess so far is its in the 60+mm range. So my question still stands, just wanted to give you a little more info.
    Thanks jay for any help.
    -Andrew
    What tires are you planning to run?
    If it was something massive like a 235/40/17 (which is possible), then you could put 5mm spacers up front to clear the struts and nothing in the rear.
    If you just want 215/40/17 or less, then run 15mm spacers all around.
    • schwa
      • 3
      #2447
      Originally posted by Mystikal
      The wheels are not flush or wide enough to really look right with stretched tires. I'd just go for 225/45/16 all around and enjoy the grip.
      thanx.just fitted those rims today,need spacers both front n rear or they will scub my inner wall
      • stinkydriverx
        • Jan 2008
        • 501
        #2448
        I can fit 235's???? is that with the fenders rolled?
        Im on coilovers though.
        I would be happy as hell if i could really fit 235's.
        there is already 205 40's on there right now. And the profile is a little toooo small for my liking. Im afraid the ride is going to be unbearabe. But thanks for the spacer info.
        Turbo m30 drift car build.
        500whp or bust.
        http://www.r3vlimited.com/board/showthread.php?t=256525
        • Mfever
          • May 2007
          • 1058
          #2449
          Those are now 16x8.5 ET6, which is very aggressive. Even with 205/45/16 tires stretched on, you will likely have to roll the rear fenders.
          what tire width would you suggest i run, if i were to roll the fvenders a bit... i dont want stretch either.
          • shiboujin
            • Feb 2006
            • 2791
            #2450
            continuing from my other thread
            you mentioned 10+ mm spacers for our cars are basically non existent in hubcentric form. so since even with my 5mm spacers I'm hittin frame, I'm fucked?
            • wildstoats
              • Sep 2007
              • 896
              #2451
              Have you checked out these?
              http://www.ecstuning.com/BMW-E30-318...Wheel_Spacers/
              Pricey but they exist.
              • wolfgangstbd
                • 960
                #2452
                i thought h&r made some pretty big wheel spaers for our cars
                • shiboujin
                  • Feb 2006
                  • 2791
                  #2453
                  $85 isn't bad but I need to get lug studs long enough for em. I have the extra long IE ones but I'm not sure if thats long enough.
                  Edit wait $100 with studs http://www.ecstuning.com/BMW-E30-318...cers/ES260067/
                  • Petebee
                    • Jan 2008
                    • 267
                    #2454
                    Quick question...can I use the lug bolts from my OEM 14" steelies with OEM bottlecaps? Gonna add some RT-615s and go tear up the cones, but need to make sure the lugs will work.
                    • omar85
                      • 331
                      #2455
                      nevermind.
                      • E30SPDFRK
                        • 5688
                        #2456
                        Originally posted by E30SPDFRK
                        Hey Jay, I'm going to be running 16x7 et10 front and et-15 rear with 205/45's. I'm gonna have some problems with the rear arches aren't I
                        As an update to this, no problems at all. Fenders are pulled a little though.
                        Byron
                        Leichtbau
                        • RainierHooker
                          • Jul 2009
                          • 2026
                          #2457
                          BBS RZ 15x6.5 ET33
                          Well today I scored some older BBS RZ's in 15x6.5 ET33 for my daily driver 325e. They are wrapped in 205/50/15 tires.
                          According to my calculations (which have every potential to be bad) I should be able to mount them right up and not get any side-effects but I want to be sure...
                          The guy I bought them from was running them on a slammed-to-the ground 325is with lots of camber. He also had them mounted with 20mm spacers.
                          My car isn't lowered at all but I have plans for H&R Sport Springs with Bilsteins to drop the car, but just slightly, after all it is my daily driver. If at all possable I want to get away without spacers. What do the gurus think?
                          1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
                          • RainierHooker
                            • Jul 2009
                            • 2026
                            #2458
                            OK, I've read through most of the thread that pertains to 15x6.5 wheels...
                            Referencing a reply to a question about 15x7 ET38 wheels it was said to go with 205/55 tires with a 20mm Spacer for a flush fit.
                            Since my wheels are ET33 by my simple math I should go with 15mm spacers for a flush fit. However for maximum 'drivability' should I go with a 10mm or 12.5mm Hubcentric as shown in the ecstuning link above? I'm not as concerned with the 'flushness' of it all, I would rather have full range of suspension play without having to worry about fender or wheel-well rub since I'm not planning on rolling my fenders...
                            -RH
                            • Mystikal
                              • 9602
                              #2459
                              Yeah, I helped a local guy do that to his S50 car. He's running RT-615s too, which run wide. No fender rolling.
                              • Mystikal
                                • 9602
                                #2460
                                Simply not possible. The wheels will be pushed outside of the fenders.
