	This is a sticky topic.
 Hmmm, as I've said in here before I'm not pro with the E30 M3 fenders. I can say that you should have quite a bit of room for spacing, but I can't be as precise as I can with the non-M cars. I'd suggest either asking someone over on S14.net or just measuring yourself. You could easily try the 5mm spacers on the rear, even stacking them to make an effective 10mm, and then checking clearance. If you want to do it the 100% way, pull a rear spring while doing this test fitting and you can then push the wheel/tire up into the fender to check for contact. Again, just some ideas as I can't be as helpful as normal.Comment
 I finally found some info on them.... Seems they are replicas of RS's, which explains why they look almost identical. I highly doubt he'll go through that amount of trouble just to get replicas to work.... Neither one of us are to fond of replicas.
 Thanks for your help though.Comment
 15x7 et30
 15X7 ET30
 I searched this massive thread and did not find an answer.
 Can I run this size wheel on a 89 325i with Bilstien Struts/shocks and springs. Lowered about 2" in front and 1.5" in rear?
 TIA1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.Comment
 Long shot, but I wanted to ask anyway.
 Borbet Type C 16x7.5
 ET30
 205/55/16 cooper touring
 not using spacers
 Q1 - Any other size of tire I can use? Eventually these tires will be replaced. As it is now, the tire is close (maybe like 4-5mm) to the strut tube.
 Q2 - What length studs should I use? 75mm, 90mm, etc?
 For reference:
 Anyone had the Falken Sincera SN 828's? I'm looking for cheap tires to get the car down to texas in. The final price installed is alittle over 270. or any suggestions of cheap tires that won't be too shitty in the rain.Comment
 Nexen N3000s are the bang for the buck that I've been using. Not sure what size you got quoted for $270, but before my dorito wholesale deals, I paid $60/tire for 215/40/16s.
 I was very happy for what they were.Erick Mahle | FullOpp Drift | YouTube
 ..::Support FullOpp::..
 FullOpp Stickers for sale!
 Feedback Thread
 Originally posted by Mr. Anderson...one of the most hardcore E30's around. :DComment
 Thanks, I'll check those out. I'm just trying to find 195/65 14's. I have found many of them but I guess I'm just shopping around at the moment.Comment
 those tires are slightly too large. 205/50-16 or 225/45-16 is the size you want. the offset is a bit high. 5-10mm spacers wouldnt hurt.Long shot, but I wanted to ask anyway.
 ET30
 not using spacers
 For reference:
 Are the spacers absolutely necessary?
 Between the 205/50-16 and the 225/45-16....which is better to go with for a track car? Will the 225 rub with and/or without 5-10 mm spacers?Comment
 Just checked turnermotorsport and the 5mm spacer required non-beveled wheel backs. Mine are beveled, even with the hubcentric rings I have on the wheels.
 So which spacers should I go with....or any at all?Comment
 That's very very close to the struts. I'd recommend 3mm spacers, even just for the front axle. You won't need longer bolts.Comment
