	This is a sticky topic.
 You currently have ET8.
 See how much room you have to play with on the inside, and make the wheels the highest offset possible. This will keep steering angles more consistent with stock (i.e. the car will be less twitchy).
 JayComment
 Its okay. Thanks for the help guys i know ive been on here more than the rest of R3V over the past week and i appreciate your help! I just have to be difficult.
 I got the Alpinas for $150, sold the tires on them [215/60 :shock:] for $40. Bought said snow tires for $120. Alpinas for winter = $230
 BTW 205/50-16s are not cheap, and the selection is crap.
 Originally posted by vladDo you know anybody else who built that many bad ass E30s?Comment
 Oh no worries man, I love this stuff. Fuck you on the Alpinas.Its okay. Thanks for the help guys i know ive been on here more than the rest of R3V over the past week and i appreciate your help! I just have to be difficult.
 I know the 205/50/16 prices are crazy, it's because not too many stock cars (lemme think...Honda Prelude, some mid-90's Volvo's...that's about it) used that size so it's a slow seller. It's basically what I really wanted for my M3 for the winter, I had a strong feeling the 205/55's would rub. That's what I get for being stubborn like TJ and running E30-offsets on an E36.
 JayComment
 Good to hear! thanks a lot once again!Comment
 Thanks. One more quick question... am I better going with ET20 and the spacers or ET8 or does it matter?Comment
 First off I hope I'm asking the right question.
 Are IE3's and billy sports with 16x9 rims 225/40/16 a reasonable setup that will look good?
 I'm not sure what offset they come in, but I was hoping for a low offset so they would look flush, then again I guess I could get studs and spacers right?
 Other than having to roll fenders, what problems could I expect to run into and what're my options to solve them.
 I'm still saving and want to do research before I buy.Last edited by red; 11-20-2007, 09:31 PM. Comment
 Well that depends on a few things.
 Are you currently using the 12mm spacers all around? If not, then keeping the wheels the same spec front/rear allows for rotating.
 Depending on the wheel design, an ET20 wheel with a spacer will have more caliper clearance than an ET8 wheel. This is completely dependent on whether the wheel manufacturer lowers the offset by extending the hub or the lip (or what combination of both).
 In general, no spacers are preferable. But they're not the end of the world either.
 JayComment
 Yeah that's a reasonable setup, and yes depending on the offset you might need spacers. Actually I pretty much guarantee you'll need at least small spacers on the front, most 16x9 wheels only come down to ET15 (which isn't low enough to clear the front struts).First off I hope I'm asking the right question.
 Other than fender rolling and strut clearance...you'll be good. Just come back here when you find the specs of the wheels you want.
 JayComment
 Sportmax fitment question
 Will the Sportmax 501 16x8 ET15 with 205-50/16 Falken Azenis' fit an '87
 325is with Bilstein sports/H&R springs without rubbing? I don't want to roll the fenders. I have used the search function and from what I have read this combination should work, my concern is with the variance in the widths that "205" section tires measure from the different tire manufacturers.
 thanks in advance.Comment
 First, there is no 205/50/16 Azenis. That said, I'll just base my answer off the "average" 205 tires.Will the Sportmax 501 16x8 ET15 with 205-50/16 Falken Azenis' fit an '87
 thanks in advance.
 It is still an aggressive setup. With your higher '87 rear arches, you will likely get away with not rolling the fenders, but I won't guarantee it.
 JayComment
 oop's, sorry about the size error, when I was shopping for Azenis's I wasFirst, there is no 205/50/16 Azenis. That said, I'll just base my answer off the "average" 205 tires.
 Jay
 looking for 15" originally and I thought that I saw that size as well. Thanks for the advice, I think that I will stick with
 something in a 15x7ish if the 16x8 is going to be tight.
 Dave.Comment
 Well if you want something big, let me recommend a setup for you:
 16x8 ET20 Rota Slipstreams (custom order from 18racing.com)
 215/45/16 Falken RT-615s
 I have recommend this setup to others before, and my friend here in Toronto is now running it. I feel this is the best setup for aggressive street/auto-x/light track for the money, and will only require a very basic fender rolling on late model cars.
 But again, if you want to be 100% sure of no rolling, get something a little less aggressive. Hell, even these same wheels with 205s will work for you.
 JayComment
