How should I set up a set of 17x8 et 15 wheels? Right now they have some 205/45/17s mounted on them, but it's time for new rubber so what's the ideal fitment? Spacers? They're going on an '87 iS w/ bilstein sports and h&r race springs, so there should be plenty of room...
	This is a sticky topic.
 About to order the spacers and studs, just wanted to doublecheck here first.
 Wheels: 15x6.5 ET38
 Tires: 205/50/15
 Suspension: HR Race Billy Sports
 Spacers: 20mm, right?
 Wheels Stud kit: 60mm, right?
 Thanks guys.turk@gutenparts.com
 Originally posted by JandersonProperly placed zip ties will hold bridges together.Comment
 turk@gutenparts.com
 turk@gutenparts.com
 Do the same offset with the rears. It will poke out very slightly more, and will look good. I'g suggest ET15 front and rear.15X8,5 ET10 in front and 15X9 ET00 in rear would be pretty fu**ing sweet. No doubt there !
 I have a similar question, looking at buying 16X8,5 for front and 16X9,5 in the rear but wondering which offset to go for. Front would be ET10 or 15 but wondering what to do about the rears. My car is lowered 60/40 and it´s a Touring (if that even matters). I am a noob when it comes to buying wheels, that being said :) my goal is to avoid using spacers.
 Has anyone here got a setup like the one I mentioned?Comment
 I'd go 215/40/17. Even with early arches and lots of spring/damper strength, you may need a minor rear roll depending on the tire used.How should I set up a set of 17x8 et 15 wheels? Right now they have some 205/45/17s mounted on them, but it's time for new rubber so what's the ideal fitment? Spacers? They're going on an '87 iS w/ bilstein sports and h&r race springs, so there should be plenty of room...Comment
 Along ways off but this fall after I recover from the 24v swap I'm thinking of buying another set of wheels as a strictly stretch/street setup and possibly put a DOT R comp on the Works for auto-x/HPDE.
 I will be running stiffer springs as well, probably 475f/650r or something close.
 17 x 9 ET 10 - 205/40/17
 17 x 9.5 ET 10 - 215/40/17
 I figure that should be about an equal stretch front and rear while still allowing for a hint of stagger'd goodness.
 Thoughts?Need parts now? Need them cheap? steve@blunttech.com
 www.gutenparts.com
 That's extremely aggressive. I'd put them up to ET14, that's about the highest possible to clear the fronts. Even still, that's a really tough fit on the rear. Pulling will be necessary.Along ways off but this fall after I recover from the 24v swap I'm thinking of buying another set of wheels as a strictly stretch/street setup and possibly put a DOT R comp on the Works for auto-x/HPDE.
 Thoughts?Comment
 Good to know, since you can custom order Works, I'd want to get the lowest offset possible for the most dish.Need parts now? Need them cheap? steve@blunttech.com
 www.gutenparts.com
