Since i already know the 235/50/17 ET42 barely fit without scraping i used this calculator to see how much difference there wold be with 225/45/16 ET35. Seems to be working, but will roll the fenders anyways.
	This is a sticky topic.
 Won't fit. Best option that i can think of is to sell the wheels.Comment
 You would be at a -7 offset, unless you doing major fendor mods that will not fit at all.Comment
 Oh wheel fitment masters out there, I need some help.
 I'm changing up my set up a little bit. I currently have 16x8.5 ET 8 wheels with 205/45 tires. I'm going to go to a 16x8.5 et 20 setup. I'm imagining that it would fit with the 205/45 tires. However, would it be possible to run a 205/50 tire with the new et 20 setup? Would I need spacers to clear the front struts? The fenders are rolled/pulled already, and the car sits on H&R/Bilstein sports.
 Thanks in advance for any help!Comment
 Racing dynamics fitment
 Hi, I'm really interested in buying a set of racing dynamic wheels. The following is a description of the size...Size = 16x8, offset 33mm
 Lug spacing is 5 on 120mm.
 Center bore = 72.56mm
 Do you think these will fit if I get a set of 5x120 to 4x100 adapters? Do you think I'll need to roll the fenders? I will be going with toyos 225x45x16s. I have h&r race springs. ThankssigpicComment
 What MM are the adapters, most of them are 20 which would put you at a 13 offset. With 225s you will probably have to roll, you will also have a decent amount of poke (wheels outside the fenders).Hi, I'm really interested in buying a set of racing dynamic wheels. The following is a description of the size...Size = 16x8, offset 33mm
 For reference, I have 16x8 et23 and it fits perfect with 225/45R16, I could actually go out another MM or 2 if I wanted but I think its right where i want it right now in the front, the rear I will probably bump out a bit.Comment
 Are these open wheels or do the bolts have a cover? If they are covered you could drill and fill then get 10mm spacers and you would get a perfect fit.Comment
 What’s up Staszek, you helped me about 10 years ago to get the right fitment for my C5 salad shooters and I’ve come for your help again!
 I’ve recently purchased some ACS II monoblocks I want to fit on my car. I’m using Nasieg’s 5 lug kit so an e36 front bearing and I’ll be using the z4 rear hub to get me to five lug. The wheel specs are 17x8 et38 and they currently have a 225/45/17 installed. I want to fit a larger tire for when I do my engine swap but I’m not sure what size spacer to use or how big of a tire I can use. I’m thinking 235 or 245/40 though. I don’t want to be super stanced ( the car is currently on a H&R sport cup kit ) so I don’t mind if they aren’t flush. I’m more about tire on the ground.
 Thank you!Comment
 Let me think about that one. Haha I gave advice 10 years ago and it worked lol :)What’s up Staszek, you helped me about 10 years ago to get the right fitment for my C5 salad shooters and I’ve come for your help again!
 Thank you!Comment
 Looking for some confirmation on tire sizes / fitment:
 I have a set of 16" Style 5s from a e38 7 series that I wanted to put on my e30 with (blox?) 18mm 5 lug adapters.
 Was planning on buying 205/45 R16 tires. Car suspension is all stock, but hoping to move to a Bilstein struts with H&R shocks here shortly.
 Will this fit without any additional work and not rub?
 ThanksLast edited by RickInABox; 02-07-2019, 02:00 PM.Comment
 I have a set of 16” oz futuras that im going to refinish with new barrels and lips. Im going to step them up to 17”. I want to go as wide as possible while replicating the same flush look I had with my 17” style 5s with 20mm adapters. How should I go about calculating this? I found a chart online that if I read correctly states I can do 4.5” barrel and 3” lip if i kept the width at 8” and et at 0 same as style 5 but not sure if thats accurate. I get lost once I try to figure out a wider fitment.Comment
