This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #2251
    Originally posted by Seph
    What I have:
    1989 325ic stock with chrome bottlecaps
    What I'm going to do:
    H&R Sport cabrio springs with bilstein shocks. Aftermarket wheels
    What I don't know:
    A hell of a lot... and
    What is best tire/wheel choice for a smooth ride yet capable of being pushed around corners. This will NOT be a track car and I do not want coilovers as this is a cruiser/DD. I don't want to modify the fenders at this time. Maybe later though.
    The smaller the wheel, the more compliant the ride (given a constant tire). Some clean 15" BBS wheels or similar with 205/55/15 tires would be an ideal setup. Even a set of Euroweaves, which are usually for sale for a great price on here, would be nice. For tires, the Falken ZE-912 is pretty much exactly what you want.
    Also just a side note, Koni dampers provide a much softer ride than the Bilsteins. MUCH.
    • Mystikal
      • 9602
      #2252
      Originally posted by ciz28
      Will 225/50R15's fit on euroweaves (15x7 et24?) without any rubbing, rolling, spacers, etc? I am currently running 205/60R14 Falken Ziex ZE-512's on basketweaves, but there doesn't seem to be a whole lot of clearance between the tire and the front strut housing, maybe 1/4"? I am running H&R sport springs with Bilstein sport shocks on my '91 318is, so it's a very mild drop. But if there's any chance of rubbing even with 4 adults loading the car down, I'd rather just stick with some 205/55R15's.
      On a related note, would 225/50R15 tires look too fat on a 7" wheel? A 225 tire would have almost 9" of tread width which seems like a lot for a 7" wheel, whereas a 205 tire would have 8" of tread width. I'd like to maintain a nice square, properly proportioned tire.
      It will be close, but it shouldn't rub, even loaded up.
      Here's a shot of my old 225 512s on a 15x7:
      • Mystikal
        • 9602
        #2253
        Originally posted by lifeiskaos
        i'm looking at 245/40/17's on a 17x9
        Rear only, or all around?
        • Mystikal
          • 9602
          #2254
          Originally posted by BadCab
          I am going to pick up some used Kopi's tommorow. I am assuming they are 17x7.5 ET20. I have a 92 318ic. I understand the 215/40-17 will fit all around. Can i go to a 235/40-17 on the rear?
          Thanks
          Glen
          Not without some rather significant rear fender rolling. I've seen it done, but it did take quite a bit of work.
          • optimusp517
            • Oct 2005
            • 797
            #2255
            Here's a question. I've got both front and rear fenders rolled. Rears are fine, front fender used to rub when I had my coils in there. I'm running 225/50-15 up front. Should I bump it down to 205/55-15 instead? Would that solve the issue?
            • optimusp517
              • Oct 2005
              • 797
              #2256
              Oh btw it's rubbing the front fender lip when I go up driverways and stuff. That's where I run into issues.
              • ciz28
                • Jul 2008
                • 13
                #2257
                Thanks for the reply, that picture helps a lot too!
                • Mystikal
                  • 9602
                  #2258
                  What's the offset and width of the wheels?
                  • Stephen
                    Шлем ишака
                    • 10774
                    #2259
                    Ok, here i go aagian.
                    So 15x8 et 15
                    So, im thinking 10mm spacer rear, nothing in front.
                    But for the tires, id like to avoid the baloonin tires look, so maybe a 215/45?
                    Or should i aim for wider?
                    • Mystikal
                      • 9602
                      #2260
                      So 15x8 et 15
                      Even with a 205, you're looking at fender rolling and stiff springs to get that to work. I'd actually recommend 195/55. That's a really aggressive setup.
                      • Stephen
                        Шлем ишака
                        • 10774
                        #2261
                        Alrighty. Im on IE3s, so stiff, but not coils. I may do the 195s then. Should i just do no spacers at all in the rear?
                        • Mystikal
                          • 9602
                          #2262
                          It won't hurt to mount them without the spacers to see how you like it. I'd get 205/50s, don't buy spacers off the bat, then add what you want (and subsequently roll the fenders too).
                          • Stephen
                            Шлем ишака
                            • 10774
                            #2263
                            Ok. Its worth noting my car is an early model, a little hard to tell in the sig
                            • Eric
                              • 5142
                              #2264
                              hey mystikal, got another one for you.
                              I just bought some 245/35/18 falken fk452 for a set of 18x8.5 BBS RC's in et13. how will the tire sit on the rim? blocked, bloated, stretched?
                              thanks
                              • devonjordan
                                • Jul 2006
                                • 2386
                                #2265
                                Nevermind, wont fit.
                                Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
                                Help a brother out, buy your detailing products here...
